Home > Puma (Tdci) > BAS Intercooler Fitment
trailbear
Gents
Probably a silly question but has anyone fitted the BAS Intercooler to their vehicle themselves?
I note from the website that it mentions to remove the lower plastic tags on either side of the radiator
Which interfere with the aircon radiator.
Is this achieved easily enough with the radiator in situ, the last thing I want to do is
start dismantling parts of the vehicle and ending up with a nightmare ( which seems to happen quite a lot lately 😳 ) and then ruining a perfectly good radiator.
I could get the local Indy to fit it but I am am loathe to pay for things that are easy enough to be achieved at home!
Any advice is appreciated.
Post #899811 24th Apr 2021 10:03am
bear100
Yeah ive done it, not too long ago either, when i asked at one of the shows Pete said it will take one of his boys 30 mins to fit it if i bought it there, sods law i went away and called later that day and they had sold out.
i would say an hour would be more realistic but i decided to fit the silicone hoses at the same time, then i decided to address the rusty aircon rad brackets then i decided to paint the front grill, then i fitted the bonnet catch guard the list goes on!
Its not to bad a job really and well within the DIY mechanic with basic knowledge capabilities, a bit fiddly but nothing a cup of tea or a beer in-between wouldn't fix
Thumbs Up 2016 Range Rover Autobiography 4.4 TDV8
2010 110 XS Utility 2.4TDCI
1993 110 csw 200 tdi (gone)
1994 90 HT 300 tdi (gone)
1994 discovery 300tdi (gone)
90 hybrid 3.5 v8 (gone)
Post #899846 24th Apr 2021 1:55pm
trailbear
That’s what I wanted to hear.
The intention much like yours is to fit the cable guard, the silicone hoses
and just a general tidy up of the crusty / rusty areas that are hard to address otherwise.
Thanks for the info 😬
Post #899847 24th Apr 2021 2:06pm
Linds Hanson
The lugs are easily cut off just being thin plastic ideally by means of a battery hacksaw but at worse a hacksaw blade wrapped in a rag. The silicone hoses can be difficult to push on due to the restricted space around the intercooler stubs and radiator/inner wing confines. Make double sure that the bonnet cable release is operating correctly before refitting the front panel as its very difficult to access the catch once everything is refitted. Also check the bonnet safety hook point doesnt collide with your new cooler!
Post #899854 24th Apr 2021 2:51pm
trailbear
All very good advice, it sounds like some of it at least is based on
Personal experience which is how I generally find out where I have went wrong. 😳
Always better to be prepared for the job in hand and some of that information is probably
Not what I would have considered Thumbs Up
Post #899857 24th Apr 2021 3:20pm
Rossy110
Scotland 2014 Defender 110 Puma 2.2 XS CSW Sumatra Black
Afternoon Trailbear
Where about in Scotland are you based? I fitted my intercooler a couple of years ago and currently running a stage 2 from Alive.
More than willing to assist if you are near Aberdeen 😉
Rossy
Post #899867 24th Apr 2021 4:08pm
bear100
i used Jenolite on the rusty bits especially the aircon brackets, worked a treat and well recommended
let us know how you got on Thumbs Up 2016 Range Rover Autobiography 4.4 TDV8
Post #899868 24th Apr 2021 4:10pm
trailbear
Rossy110, I would have taken you up on the offer but
unfortunately, I am based just outside Edinburgh.
I have never used Jenolite before, must give that a go.
Are there any pointers to aid the fitment of the hoses, dunking in hot water to soften up etc.
Or is that a no no with silicone hoses🤔
Post #899873 24th Apr 2021 4:40pm
bear100
The hoses are the worst and very tight to get on, i used silicone lubricant but i don't think it helped much, not sure about the hot water trick 2016 Range Rover Autobiography 4.4 TDV8
Post #899877 24th Apr 2021 5:12pm
Benrlelliott
United Kingdom 2008 Defender 90 Puma 2.4 XS CSW Aintree Green
To add to this, if I may, are there any consumables I should replace while at it (have a BAS ready to go too)? Thinking aircon condenser as mine is shot, anything else?
Post #899888 24th Apr 2021 7:28pm
trailbear
Used to stick the end of the hoses in a mug ( or other receptacle ) of hot water when having to fit new hoses
To vehicles, softened them up and made them easier to go over the ends of the pipe work although
not sure if it is advisable or even possible to do the same with silicone hoses.
Post #899898 24th Apr 2021 10:13pm
familymad
Works the same and what I did to fit the BAS cooler and silicon hoses 1951 80" S1 2.0
1995 110 300TDI
1995 90 300TDI
Post #899904 25th Apr 2021 6:00am
trailbear
Excellent, good to know the old ways still work.
That’s what I’ll be doing then.
Post #899916 25th Apr 2021 8:24am
Tribord
France 2011 Defender 110 Puma 2.4 XS DCPU Zermatt Silver
I fitted the BAS intercooler and was expecting the silicon hoses to give some challenges. I just left them outside in the sun for a short while before the job, and they all went on quite easily. For once, I was pleasantly surprised!
Post #900018 26th Apr 2021 7:22am
trailbear
Haha, perhaps I would need to leave them outside for the whole summer up here
In Scotland to make any difference Laughing
Post #900021 26th Apr 2021 7:35am
