Home > Maintenance & Modifications > Scratch Removal Advice Please |
JPE Member Since: 19 Nov 2018 Location: South West England Posts: 335 |
I enjoyed a fantastic day on Salisbury Plain, it felt so good to finally be able to escape the house!
Along the way I picked up some scratches to my usually pristine firenze red body work on my puma 110. Does anyone have any recommendations on the best products / tools to help be rid of them? |
21st Apr 2021 6:36am |
Clemmo Member Since: 03 Aug 2012 Location: Mile Oak Posts: 1218 |
As stated above..
It depends on Depth of scratch Type of finish.. ie solid colour or lacquer coat? Very minor scratches will hide with T- cut or similar. Slightly heavier scratches use Farecla G3. Both products use by hand. A body shop is the next step...unless you want to try machine polishing yourself. Clemmo👍 Make today a little better than yesterday but not so good as tomorrow.... Defender 90 HT............Pangea Green BMW X3 Msport............Carbon Black Mini Electric................Grey. (wow!) MGB Roadster……..........Vermillion 17k miles Honda Benly CD200....Maroon --------McLouis Fusio........7.4m of fun |
21st Apr 2021 8:10am |
Leamreject Member Since: 19 Dec 2020 Location: Middle Earth - Leamington Spa Posts: 970 |
If you rub a wet finger over the scratch and it disappears normally it will only need a light finesse cut back, anything deeper really depends on the severity of it.
Will they show in a photo? Ride like you stole it!! If I’m not on a bike it’s because only a 4x4 will do… 2011 2.4 Puma 90 HT |
21st Apr 2021 9:52am |
Thanks for the advice, I'll look into those products. I washed it to get all (well some) of the Salisbury mud off & I couldn't see the scratches when it was wet, which I'm taking to be a good sign that they are not so deep. Thanks again.
21st Apr 2021 5:12pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20378 |
Personally I’d not go any more course than Farecla G10 unless experienced, and then up to polish. Go with the lightest possible first the clear is not very thick so be very careful.
It is however quite hard which is a good thing, at least on mine it is but you don’t have much thickness to play with. From what you’ve said a basic standard polish should work. $W33T $0U7H3RN $UG4R 🇬🇧🏴🏴🏴🇮🇪🇺🇸⛽️🛢️⚙️🧰💪 |
21st Apr 2021 5:17pm |
markb110 Member Since: 22 May 2010 Location: Guildford Posts: 2639 |
Once you have had your first 50 scratches you stop worrying about them, even more so when you get the mother of all scratches down one side that means all the others just melt away......
This was 'collected' on the lane to Salisbury Race Course. Click image to enlarge Added benefit is that you can pull out in front of leased BMW'S and Mercedes and nobody wants to park next to you...win win |
21st Apr 2021 6:49pm |
I Like Old Skool Member Since: 23 Feb 2015 Location: Manchester Posts: 809 |
^^^^ This is the 'correct' finish for a real Landrover
21st Apr 2021 9:26pm |
spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4663 |
""Go faster stripe?" 1982 88" 2.25 diesel
22nd Apr 2021 2:40pm |
Matt110 Member Since: 29 Jun 2014 Location: UK Posts: 683 |
There was me hoping Salisbury would be fairly non-scratchy!!! |
22nd Apr 2021 2:52pm |
99.9 % of the Plain is fine, go and enjoy.
The lane on the day runs from just south of Salisbury to the racecourse. It fact the last time I was there it was narrower and lower than the Defender.. As councils aren’t clearing lanes it is down to vehicle use to keep them open. It’s all to easy for the councils to do nothing and then down grade a lane. Unfortunately with thinking like this the overgrowth also hinders horse riders, cyclists and other users. |
22nd Apr 2021 3:13pm |
