Home > Technical > Fuel gauge not moving
Page 3 of 3 <123
dorsetsmith
Does this absolutley isolate the fault to the sender unit? or a problem wiring in loom and tank unit plug
only way to prove that is isolate sender unit from the chasse loom wiring and test resistance value at sender only
Post #898756 17th Apr 2021 12:13pm
james.works
France
I've done that and it reads that same 480ohms at the sender unit itself
Post #898842 18th Apr 2021 8:48am
james.works
France
I've also removed the sender, not entirely from the tank but removed the ring and lifeted it up, it reads higher resistance at that point, 600ohms, but went back to the original stuck at 480ohms reading when I put it back in the full tank.
Is this a faulty sender? Can it be fixed or should I replace it?
Thanks!
Post #898941 19th Apr 2021 6:45am
dorsetsmith
replacment sender part number
LR030038
Fuel Tank Sender - 110/130
Fuel System / 2.2 Tdci Puma
With the tank unit removed from the tank see when you move sender arm up down will resistance change ?
Post #898943 19th Apr 2021 7:05am
james.works
France
I'll try that. I didn't remove it completely from teh tank yesterday as I wasn't sure why it wasn't coming up easily, didn't want to damage it, I'll do it asap
Post #898944 19th Apr 2021 7:11am
dorsetsmith
you saying that the tank unit was replaced with the engine how long ago as most LR parts have two year warranty from date of perchance
Post #898945 19th Apr 2021 7:21am
james.works
France
It's about six weeks old, original lr part. I'll take it out and inspect it properly, is there anything I should be looking for?
Post #899210 20th Apr 2021 5:52pm
dorsetsmith
check plug and socket and wires on the unit
Post #899674 23rd Apr 2021 7:10am
Page 3 of 3 <123
