Home > Td5 > headlamp improvement |
abomb1969 Member Since: 23 Jul 2011 Location: Welwyn, Hertfordshire Posts: 79 |
I have WIPAC Quadoptics and crap bulbs by the look of it, is it worth upgrading to the Crystals?
18th Sep 2011 8:15am |
bm52 Member Since: 04 Apr 2010 Location: Kent Posts: 2189 |
Hi, I put Crystals on my old 300 because the lights were complete cr@p. but so far the standard Puma lights with Philips Extreme seem OK.
Are Crystals that much better than standard Puma lights? BM52 |
18th Sep 2011 7:26pm |
adafish Member Since: 30 Mar 2009 Location: atherstone Posts: 1381 |
treat yourself's to some LED ones Tim sells @ mobilecentre...they've dropped in price..I drive a few Landy's with them fitted, even my own and very very crisp white light... Putting Dreams on Drives at JLR Solihull..
18th Sep 2011 8:35pm |
Zinke Member Since: 27 Jan 2009 Location: Scunthorpe Posts: 670 |
What are they like in the snow though? Where the heat from normal types of bulb melt the ice and snow off the lenses, what happens with LED light? |
19th Sep 2011 8:14pm |
roel Member Since: 08 Aug 2009 Location: Lelystad Posts: 2039 |
Probably something like this:
Click image to enlarge Roel 1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
20th Sep 2011 6:35pm |
There is some heat generated at the rear of the lamp which is blown forward by a small fan onto the glass. The lamp has been tested down to minus 20 degrees......HTH.....Ada Putting Dreams on Drives at JLR Solihull..
20th Sep 2011 8:54pm |
noworries4x4 Member Since: 24 Dec 2010 Location: Newton Abbot Devon Posts: 1195 |
I've got the Cibe conversion lenses with piaa bulbs they are definatly the way foward avalable on the net from Europa car spares, got them on the racer aswel. If everything is under control you are not going fast enough.
Every Day 16 MY Discovery 4 Commercial Workshop and Escort Vehicle Weekends 07MY L322 TDV8 Vogue SE Series 1 80" 3ltr 6cyl with overdrive No Worries 4X4 |
20th Sep 2011 10:10pm |
