Home > Puma (Tdci) > Fuel cooler 2016 2.2 Puma
RustyM
England 2016 Defender 110 Puma 2.2 XS CSW Corris Grey
Hi all,
Been a while since I posted, still active Exclamation
So I am looking at my 2016 2.2 Puma fuel system and I don't appear to have a fuel cooler Question
Does anyone else have a 2.2 and not have one? I am assuming these were not always fitted Question Can someone post a real life picture of one for my reference.
Thanks
Matt 90 & Wolf
110 XS
Previously owned SI SII SIIa SIII & Light weight (air portable)
Post #897649 12th Apr 2021 8:19am
Marks Landy
United Kingdom 1985 Defender 90 200 Tdi SW Java Black
Canโ€™t see one on my 2.2
Post #897782 12th Apr 2021 6:54pm
llessur
I don't know when or why it changed but here are the with and without parts
Post #897783 12th Apr 2021 7:04pm
JPE
United Kingdom 2013 Defender 110 Puma 2.2 XS CSW Firenze Red
My 2013 2.2 has one.
Post #897817 12th Apr 2021 8:12pm
JPE
According to lrworkshop.com the bypass is fitted from chassis VIN DA432380 onwards. Diagrams & part numbers can be found here -> https://www.lrworkshop.com/diagrams/land-r...mbly_45019
Post #897821 12th Apr 2021 8:24pm
HardCharger
2.4 Puma has a fuel cooler, the 2.2 Puma, does not.
It does, however, have a fuel system related pipe there where the fuel cooler should be. This is why it's still recommended to have a fuel cooler guard as it protects this wee pipe from the dangers of the world.
Post #897864 13th Apr 2021 3:38am
Dinnu
My 2012 2.2 has one too. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #897871 13th Apr 2021 6:09am
Rashers
Sorry to hijack the thread but I have a stupid question.
Apart from the obvious, what does the fuel cooler do (why is it fitted) and is it detrimental on vehicles where they have omitted them?
Post #897878 13th Apr 2021 6:53am
Angus_Beef
Norway 2015 Defender 110 Puma 2.2 SW Corris Grey
my 2015 2.2 with DPF has one, contrary to what lrworkshop would indicate. Roaming around ๐Ÿ‡ณ๐Ÿ‡ด๐Ÿ‡จ๐Ÿ‡ญ
Post #897886 13th Apr 2021 7:13am
llessur
I had it explained to me that modern high pressure injection engines leak more fuel, back to the tank,from the injector returns. Because the pressure is increased by the fuel pump, the temperature is raised.
When Diesel is heated it's ability to lubricate is reduced which is very harmful to close tolerance components like the injection pump. Also heated Diesel reduces engine power. I think its something like a a rise of 10 ยฐC causes a power loss of 7.5%.
Of course I think this was over simplified explanation and I presume there are many other effects. I bet emissions are effected and I wonder how our plastic fuel lines and tank cope with the increased temperatures.
Post #897929 13th Apr 2021 9:26am
Dinnu
Interesting. The problem is that liquids are incompressible, so the fuel pump is not compressing the diesel, but is only increasing the pressure. Very different thermodynamics vs fluid dynamics.
Although the name is 'cooler', I always thought that it is pre heating the fuel to lower emissions. But I could be wrong. I never investigated it in detail. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #897941 13th Apr 2021 10:38am
RustyM
Hi all,
Thank you for all your responses.
So mine also has "The metal pipe" I do a lot of hot climate travel in my defender.
I wonder if it is a "Fuel cooler" or if it serves another purpose also.
Given that I use mine mostly in hot climates should I retro fit this "cooler"?
Thank you all in advance for your help.
Kind regards
Matt 90 & Wolf
110 XS
Post #897961 13th Apr 2021 11:44am
Dinnu
Perhaps what RustyM says consolidates more the possibility that the 'cooler' is actually a 'warmer'. If the defender was destined for a warm climate, then possibly they skip the cooler as it is not needed!!
Perhaps you can check the fuel tank and fuel filter if they are becoming too warm after a long drive. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #898025 13th Apr 2021 4:18pm
Angus_Beef
I was wrong. Maybe Iโ€™ve been reading the repair manuals too long - Iโ€™d have wagered money I had one!
EDIT: now Iโ€™m wondering where the low point to drain the coolant is since the workbook says to drain at the fuel cooler, and there is no drain plug on the radiator... ๐Ÿค” Roaming around ๐Ÿ‡ณ๐Ÿ‡ด๐Ÿ‡จ๐Ÿ‡ญ
Post #898026 13th Apr 2021 4:21pm
You can drain from the thermostat hose, maybe not quite the very lowest point but very close. No Guts, No Glory.
๐Ÿ‡ฌ๐Ÿ‡ง๐Ÿด๓ ง๓ ข๓ ฅ๓ ฎ๓ ง๓ ฟ๐Ÿด๓ ง๓ ข๓ ท๓ ฌ๓ ณ๓ ฟ๐Ÿด๓ ง๓ ข๓ ณ๓ ฃ๓ ด๓ ฟ๐Ÿ‡ฎ๐Ÿ‡ช๐Ÿ‡บ๐Ÿ‡ธโ›ฝ๏ธ๐Ÿ›ข๏ธโš™๏ธ๐Ÿงฐ๐Ÿ’ช
Post #898061 13th Apr 2021 7:12pm
