Home > Puma (Tdci) > Smokey
Howard
United Kingdom 2012 Defender 110 Puma 2.2 PU Alpine White
Smokey
I find when I start my 2010 2.4 the exhaust fumes are eye watering until the engine warms up. Is this normal or is it over fuelling on cold start?
Post #897779 12th Apr 2021 6:43pm
Bluest
I don't know if its normal, but mine does it. Keep meaning to check for exhaust leaks on a cold morning. 2007 110 TDCi Station Wagon XS
Post #897784 12th Apr 2021 7:05pm
Leamreject
Italy 2011 Defender 90 Puma 2.4 HT Fuji White
Is it white smoke on cold start that disappears when it gets warm? Ride like you stole it!!
If I’m not on a bike it’s because only a 4x4 will do…
2011 2.4 Puma 90 HT
Post #897798 12th Apr 2021 7:53pm
Julie
France 2012 Defender 110 Puma 2.2 SW Keswick Green
I had those loads of white smoke while testing a 2.4 I wanted to buy.
That white fog of death disappeared as soon as the engine warmed up, what took 2...3 min Neutral
As this indicates the head needs replacement, I didn't buy that one.
Sorry for spreading bad news...
The most common sign of a blown head gasket is exhaust smoke. White smoke indicates that your car is burning coolant that is leaking into the cylinders. A similar problem is indicated by blue exhaust smoke, though this is a sign of oil leaking from the gasket. The exhaust pipe may also be emitting excess moisture or dripping water.
From : https://www.theday.com/article/20180407/biz09/180409547
Post #897808 12th Apr 2021 8:04pm
Howard
No white smoke, Jus link busting eye watering carbon smoke . Once warm it’s fine.
How does the cold start work?
Post #897829 12th Apr 2021 8:41pm
andydef90
United Kingdom 2014 Defender 90 Puma 2.2 HT Corris Grey
think its a defender trait mine is the same on cold start .
its fine in warmer weather just for peace of mind keep a eye on your expansion bottle see if it keeps at the same level .
also check the cap for emulsification
Post #897975 13th Apr 2021 1:00pm
Bundy
Mine smokes and stinks too on a cold start.
Soon goes and I'm learning to ignore it Laughing
Post #897979 13th Apr 2021 1:12pm
CharlieDonuts
France 2008 Defender 90 Puma 2.4 SW Galway Green
Mine does it. (2008 2.4) No white smoke. I have soot marks on the exhaust - to turbo flange. I've had it machined flat and I have an after market gasket but it still blows a bit.
Post #898120 14th Apr 2021 7:39am
