Home > Puma (Tdci) > Smokey |
Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 4225 |
I don't know if its normal, but mine does it. Keep meaning to check for exhaust leaks on a cold morning. 2007 110 TDCi Station Wagon XS
12th Apr 2021 7:05pm |
Leamreject Member Since: 19 Dec 2020 Location: Middle Earth - Leamington Spa Posts: 970 |
Is it white smoke on cold start that disappears when it gets warm? Ride like you stole it!!
If I’m not on a bike it’s because only a 4x4 will do… 2011 2.4 Puma 90 HT |
12th Apr 2021 7:53pm |
Julie Member Since: 07 Oct 2017 Location: Nantes Posts: 512 |
I had those loads of white smoke while testing a 2.4 I wanted to buy.
That white fog of death disappeared as soon as the engine warmed up, what took 2...3 min As this indicates the head needs replacement, I didn't buy that one. Sorry for spreading bad news... The most common sign of a blown head gasket is exhaust smoke. White smoke indicates that your car is burning coolant that is leaking into the cylinders. A similar problem is indicated by blue exhaust smoke, though this is a sign of oil leaking from the gasket. The exhaust pipe may also be emitting excess moisture or dripping water. From : https://www.theday.com/article/20180407/biz09/180409547 |
12th Apr 2021 8:04pm |
Howard Member Since: 06 Nov 2012 Location: Oxfordshire Posts: 42 |
No white smoke, Jus link busting eye watering carbon smoke . Once warm it’s fine.
How does the cold start work? |
12th Apr 2021 8:41pm |
andydef90 Member Since: 09 Feb 2015 Location: yorkshire Posts: 617 |
think its a defender trait mine is the same on cold start .
its fine in warmer weather just for peace of mind keep a eye on your expansion bottle see if it keeps at the same level . also check the cap for emulsification |
13th Apr 2021 1:00pm |
Bundy Member Since: 21 Sep 2020 Location: Cheshire Posts: 98 |
Mine smokes and stinks too on a cold start.
Soon goes and I'm learning to ignore it |
13th Apr 2021 1:12pm |
CharlieDonuts Member Since: 16 Jun 2019 Location: Illiers Combray Posts: 133 |
Mine does it. (2008 2.4) No white smoke. I have soot marks on the exhaust - to turbo flange. I've had it machined flat and I have an after market gasket but it still blows a bit.
14th Apr 2021 7:39am |
