Home > General & Technical (L663) > Terrain Response 2 - worth the cash?
MBurns48
United Kingdom 2002 Defender 90 Td5 HT Baltic Blue
Hello gents. I'm considering putting an order in for a new Defender. It will get used off road (greenlaning/touring mostly).
What's the consensus with TR2? Is it worth adding the Advanced Offroad Capability Pack at just over £1k? I'd definitely be getting the air susp and rear diff auto locker but I'm just not convinced that the "old" TR is not fit for purpose?
Thoughts from those that have used it on the new Defender?
Post #897366 11th Apr 2021 9:37am
Simon Audi
I think now you can add the ATPC on its own or in the TR2 pack
When I bought mine it was for the ATPC.
I have not used any of it yet... but the only benefit beside the ATPC is the Auto function - but if you are familiar with the LR TR modes - not sure it is worthwhile. - I guess you can manually lock the Diffs if you want too.
Better spend the same money on the E Diff.. ?
Post #897383 11th Apr 2021 10:41am
J77
I have none, only the standard TR, no air suspension either.
It’s the most capable off road vehicle they’ve built, only if you spend thousands on off road packs Rolling Eyes my Discos done well without it. 24MY 90 D250 HSE, Tasman Blue
Post #897389 11th Apr 2021 11:08am
I didn't that was possible any more?
Post #897410 11th Apr 2021 12:23pm
Philip
It is possible, Configurable Terrain Response can control the diffs.
Post #897413 11th Apr 2021 12:27pm
Do you mean this:
What does "slip limited" mean? If it means 100% locked, wouldn't it say that?
Post #897418 11th Apr 2021 12:45pm
Philip
What makes you think 100% locked is what’s always best?
Post #897420 11th Apr 2021 12:52pm
Retroanaconda
There are three diff modes on TR2 for vehicles with the locking rear diff fitted:
Post #897426 11th Apr 2021 1:22pm
Retroanaconda
Forgot to say yes it probably is worth it purely for the ability to manually lock the diffs, but if you’re not too concerned about warranty you can buy it from a company that will enable it in the cars settings for a few hundred quid rather than pay LR a grand for it.
Post #897428 11th Apr 2021 1:28pm
So you manually "lock" the diff but the iGuide states "a status bar around the icon indicates the amount of lock being applied":
Which seems to confirm that they do not operate in an on/off fashion but rather in an almost infinitely variable fashion or at least 3 phased steps ~ just what controls the level of wheelspin is the question?
Post #897433 11th Apr 2021 2:23pm
Philip
Wheel speeds, essentially (although as I understand it, the e-diff has some continual degree of lock in off-road modes, whatever the display graphic is doing)
Post #897435 11th Apr 2021 2:38pm
It's this language, from JLR, I find frustrating. I can't be the only person to think locked/unlocked are binary terms rather than "degrees of lock" through the e diff clutch pack.
I'm also wondering what benefit the e diff is in creating resistance through the clutch pack when at the other end of the driveshaft the brake caliper can do exactly the same task?
Post #897439 11th Apr 2021 2:55pm
J77
I think that applies to vehicles such as mine where I can’t manually lock the diff? Or set to auto for those with configurable TR? 24MY 90 D250 HSE, Tasman Blue
Post #897440 11th Apr 2021 3:00pm
So it would need someone with an e diff to "lock" it:
[/quote]
And either jack the back end up to demonstrate or drive it in a straight line in a car park and film the diff lock screen to see what it did?
Shame Powerful UK has got it ~ can't see anyone else going to the effort?
Post #897446 11th Apr 2021 3:15pm
Philip
Really not clear what the issue is here, there are all sorts of systems which don’t need to bother an operator with the most precise minutiae of their operation. Presumably you’ve got rid of the damped coolant temperature gauge in all your cars? Fitted a live wheel speed vs ignition timing vs brake pressure gauge to watch the traction and stability controls work?
Post #897450 11th Apr 2021 3:25pm
