Home > General & Technical (L663) > Access, Normal and Off Road heights |
Simon Audi Member Since: 19 Nov 2020 Location: Newport Posts: 544 |
looks about right - drops around 45 mm
6th Apr 2021 5:40pm |
6th Apr 2021 5:58pm |
zilch Member Since: 11 Sep 2019 Location: Whitsundays & Sydney Posts: 823 |
took a picture of our New Defender and a friends in access height next to our RRS (L320) the Sport was in
normal ride height, they looked to be about the same level although each was in a different setting. That may give the illusion of the Defender not reducing its height compared to the other LR air suspension models. Click image to enlarge yet another pommie bar steward down under MY20 110 P400 SE Defender MY10 3.0 RR Sport |
6th Apr 2021 9:54pm |
Sepp Member Since: 05 Oct 2020 Location: Bavaria Posts: 114 |
Have you measured the height differences and compared with specs? Access is speced -40mm compared to Normal. |
7th Apr 2021 10:29am |
RRUK Site Supporter Member Since: 31 Mar 2010 Location: Leicestershire Posts: 2025 |
Not yet but that’s my next thing to do. 2016 D4 HSE
1998 110 TUM HS FFR Hard Top XD WOLF 1982 Series 3 SWB Petrol |
7th Apr 2021 12:54pm |
Q86ARR Member Since: 28 Feb 2017 Location: Earth Posts: 38 |
Ride height:
Normal - 90 vehicles 218 mm (8.58 in) Normal - 110 vehicles 218 mm (8.58 in) Off road 1 40 mm (1.57 in) above normal Off road 2 75 mm (2.95 in) above normal Access (maximum) 40 mm (1.57 in) below normal High speed 13 mm (0.5 in) below normal |
9th Apr 2021 7:44am |
Well, I measured mine just now (a 110) and the heights were as follows from the ground to the wheel arch lip
Access - 850mm Normal 890mm Off Road 940mm 2016 D4 HSE 1998 110 TUM HS FFR Hard Top XD WOLF 1982 Series 3 SWB Petrol |
9th Apr 2021 10:54am |
You need to measure from the centre of the wheel to the edge of the wheel arch
9th Apr 2021 12:15pm |
