Home > General & Technical (L663) > Access, Normal and Off Road heights
RRUK
Maybe it’s just me getting used to my new Defender, but having only ever driven Land Rovers and had most of them with air suspension I think I speak from experience.
I’ve noticed that when I select Access mode on this one, it doesn’t seem to drop much at all, whereas my D3 and my RRS drop significantly.
Here’s three photos to show you the differences. I’d appreciate your feedback when compared to your car, so I can potentially get the Dealer to add this to my list of snags.
Photos in order: Access - Normal - Off Road
 2016 D4 HSE
1982 Series 3 SWB Petrol
Post #896239 6th Apr 2021 4:13pm
Simon Audi
looks about right - drops around 45 mm
Post #896272 6th Apr 2021 5:40pm
Simon Audi
Post #896279 6th Apr 2021 5:58pm
zilch
Australia
took a picture of our New Defender and a friends in access height next to our RRS (L320) the Sport was in
normal ride height, they looked to be about the same level although each was in a different setting.
That may give the illusion of the Defender not reducing its height compared to the other LR
air suspension models.
 yet another pommie bar steward down under
MY20 110 P400 SE Defender
MY10 3.0 RR Sport
Post #896341 6th Apr 2021 9:54pm
Sepp
Germany
Re: Access, Normal and Off Road heights
Have you measured the height differences and compared with specs?
Access is speced -40mm compared to Normal.
Post #896430 7th Apr 2021 10:29am
RRUK
Not yet but that’s my next thing to do. 2016 D4 HSE
Post #896461 7th Apr 2021 12:54pm
Q86ARR
Ride height:
Normal - 90 vehicles 218 mm (8.58 in)
Normal - 110 vehicles 218 mm (8.58 in)
Off road 1 40 mm (1.57 in) above normal
Off road 2 75 mm (2.95 in) above normal
Access (maximum) 40 mm (1.57 in) below normal
High speed 13 mm (0.5 in) below normal
Post #896871 9th Apr 2021 7:44am
RRUK
Well, I measured mine just now (a 110) and the heights were as follows from the ground to the wheel arch lip
Access - 850mm
Normal 890mm
Off Road 940mm 2016 D4 HSE
Post #896910 9th Apr 2021 10:54am
Q86ARR
You need to measure from the centre of the wheel to the edge of the wheel arch
Post #896926 9th Apr 2021 12:15pm
