![]() | Home > Puma (Tdci) > 2.4tdci engine oil leak |
TamarBlue11 Member Since: 25 Sep 2020 Location: England Posts: 228 ![]() ![]() ![]() |
No photo in the post?
Willfindlay Member Since: 08 Mar 2021 Location: Yorkshire Posts: 24 ![]() ![]() ![]() |
![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge Sorry, thought I’d added them. Here they are. |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20711 ![]() ![]() |
Sump needs replacing and a new seal, I had that a couple of years ago.
At least it looks that way unless it’s from even further up. It was leaking from the seal on mine, which looks similar to what you have going on there. It’s not overly expensive luckily, but do remember the sump is really important and some have been known to go though if very aged and then you’d have big problems. They are surprisingly thin. WeWillWin🇬🇧🇺🇸 ⛽️🛢️⚙️🧰💪 |
It is above the sump I think, and dripping down and blowing back across it.
MMR1988 Member Since: 29 Oct 2016 Location: Chemnitz Posts: 54 ![]() ![]() ![]() |
Maybe you could do a picture from the top side.
Maybe it's the seal behind the crankshaft pulley or it's simply the plastic cover form the front cover which is covering the high pressure pump gear or it is something else. It's just not to see on these pictures. /Max |
Is this the plastic cover ?
Yes, it is. The LR Part number is: LR004639, the Ford number is: 3S7Q-6095-AA.
Badger110 Member Since: 06 Feb 2018 Location: South hams Posts: 1039 ![]() ![]() ![]() |
You may find it's the crankshaft seal or cover as this is likely to fail over time than the HP pump cover which has no force against it.
Crankshaft seal is here; https://www.turnerengineering.co.uk/lr0777...2x26759958 The covers for both the crankshaft and HP pump can be sealed with a decent motor sealant without replacing anything |
