Home > Puma (Tdci) > 2.4tdci engine oil leak
Willfindlay
England 2009 Defender 90 Puma 2.4 PU Arles Blue
Hi, does anyone have any idea where this oil could be coming from, there isn’t any sign of oil under the bonnet, it’s just below and dripping on the axle and blowing back over the sump. Thanks
Post #896207 6th Apr 2021 3:17pm
TamarBlue11
United Kingdom 2011 Defender 90 Puma 2.4 HT Tamar Blue
No photo in the post?
Post #896214 6th Apr 2021 3:59pm
Willfindlay
Sorry, thought I’d added them. Here they are.
Post #896216 6th Apr 2021 4:10pm
Sump needs replacing and a new seal, I had that a couple of years ago.
At least it looks that way unless it’s from even further up.
It was leaking from the seal on mine, which looks similar to what you have going on there.
It’s not overly expensive luckily, but do remember the sump is really important and some have been known to go though if very aged and then you’d have big problems. They are surprisingly thin. WeWillWin🇬🇧🇺🇸
Post #896236 6th Apr 2021 5:08pm
Willfindlay
It is above the sump I think, and dripping down and blowing back across it.
Post #896254 6th Apr 2021 5:49pm
MMR1988
Germany 2008 Defender 110 Puma 2.4 SW Alaska White
Maybe you could do a picture from the top side.
Maybe it's the seal behind the crankshaft pulley or it's simply the plastic cover form the front cover which is covering the high pressure pump gear or it is something else. It's just not to see on these pictures.
/Max
Post #897108 9th Apr 2021 10:30pm
Willfindlay
Is this the plastic cover ?
Post #901054 2nd May 2021 1:54pm
MMR1988
Yes, it is. The LR Part number is: LR004639, the Ford number is: 3S7Q-6095-AA.
Post #901076 2nd May 2021 6:02pm
Badger110
United Kingdom 2011 Defender 110 Puma 2.4 USW Buckingham Blue
You may find it's the crankshaft seal or cover as this is likely to fail over time than the HP pump cover which has no force against it.
Crankshaft seal is here;
https://www.turnerengineering.co.uk/lr0777...2x26759958
The covers for both the crankshaft and HP pump can be sealed with a decent motor sealant without replacing anything
Post #901077 2nd May 2021 6:29pm
