Home > Modifications & Maintenance (L663) > Where to add switch for auxiliary lights?
JackW
United States 1998 Defender 90 300 Tdi SW Coniston Green
I'm planning on adding a 10" Baja Designs light bar to the grille area and I'm wondering where is a good spot to add the switch to turn it on and off. I'll have a relay to switch power to the light bar just wanted to see what others have done to install the toggle switch to control the lights.
Post #895476 2nd Apr 2021 3:10am
It depends to an extent on what your dash currently looks like. If it's factory fresh then there may be a space in the central panel in the dash, depending on whether you already have any optional stuff there. Or is there a spare slot in the small panel to the left of the steering wheel (assuming yours is LHD) where the hazard switch is?
Beyond that, there are lots of aftermarket options from simple single switch brackets that you screw to a suitable surface to full on 'pods' that give lots of space for other toys. Take a look at the websites of Mud UK and Raptor Engineering for some ideas. Darren
Post #895497 2nd Apr 2021 7:12am
Retroanaconda
The panel down the drivers side near your knee is a favoured spot, where the dash illumination control is.
I’ve seen people fit those trailer brake controllers down there.
Post #895500 2nd Apr 2021 7:24am
Dinnu
If the locations mentioned above where the hazard and illumination control are taken, there is a squarish opening that I think takes a carling switch in the metal stiffener plate just below the binnacle. It is a little bit out of sight. On RHD vehicles, it is just right of the steering column.
https://www.google.com.mt/search?q=MUC7598...mp;bih=553
Careful about drilling holes in the lower dash, as it is the duct for the heater blower. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #895501 2nd Apr 2021 7:38am
Retroanaconda
You guys realise he’s talking about an L663 Defender?
Post #895503 2nd Apr 2021 7:50am
Ha, no! I just looked at the icon below his username, which said he has a 300tdi Rolling Eyes
What's more funny is that your answer works for both vehicles Laughing Darren
Post #895507 2nd Apr 2021 8:01am
Retroanaconda
It does - and people say there’s no lineage Laughing
To be fair he may have posted in the wrong forum.
Post #895512 2nd Apr 2021 8:08am
Dinnu
Nope Embarassed
I also saw 1998 300tdi. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #895518 2nd Apr 2021 8:54am
JackW
I assumed every one would know that I was talking about the new Defender 110. I have a Wise Owl dash in the old Defender with a row of Carling switches above the center mounted radio. But while I'm doing the winch kit to the new car I was going to add an extra light. But to further add to the confusion I also have two Series IIA Land Rovers.
Post #895535 2nd Apr 2021 10:43am
dontwakemeup
Australia
I would suggest using a switch-pro controller in the new defender.
1 wire bundle through the firewall with everything controlled externally makes it much easier.
The alternative is the warn winch has 2 auxillary outputs.
Post #895542 2nd Apr 2021 11:18am
