Home > Td5 > Emergency help needed |
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2228 |
Check the battery terminal, had possibly come loose
Failing that earth point on the transfer gearbox (drivers side) near the ECU box. Steve 02' 110 TD5 Double Cab Rebuild Thread |
1st Apr 2021 2:07pm |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5707 |
Check all fuses. Especially underseat ones.
1st Apr 2021 2:08pm |
Busarider Member Since: 14 Mar 2021 Location: Bromsgrove Posts: 63 |
Cheers guys... Fuses etc seem fine... Starter motor relay keeps blowing...??
1st Apr 2021 2:38pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17386 |
The starter motor may be jammed in mesh, in that case.
You've just learned the hard way one of the several reasons why it is good practice always to start the engine with the clutch out. |
1st Apr 2021 2:50pm |
Panic over... I was either 1)stuck starter motor or 2)bad earth to isolation switch.. .done both these jobs at the same time so not sure what was the remedy... Thanks for replies guys👍
1st Apr 2021 4:01pm |
CarMan Member Since: 29 Nov 2010 Location: Cotswolds Posts: 1861 |
Good you got it sorted Busarider Blackwolf - sorry to be a numpty but that sounds like with the clutch not depressed - it's just that I have another car non-Defender that will only start with the clutch depressed Rob 1993 200tdi 90 hard-top 1998 300tdi 90 soft-top 2016 2.2 XS 90 hard-top (sold) |
1st Apr 2021 4:14pm |
Co1 Member Since: 19 Aug 2018 Location: North Yorkshire Posts: 3676 |
Deleted due to being a numpty.
1st Apr 2021 4:59pm |
Clutch out = clutch disengaged = pedal pressed
Clutch in = clutch engaged = pedal released. This is the way it has always been, you let in the clutch to pull away, throw out the clutch to stop. It is a generational thing, young folk don't understand the terminology! |
1st Apr 2021 8:18pm |
Procta Member Since: 03 Dec 2016 Location: Sunderland Posts: 5172 |
i always start my cars with the clutch in, force of habit. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
6th Apr 2021 12:33am |
Most modern cars (the annoying ones which now seem to assume that they know best) won't let you do this - you must press the clutch pedal in order for the starter to operate. You can't start an L200 without pressing the clutch, for example.
6th Apr 2021 8:22am |
Bim Member Since: 09 Jun 2018 Location: Cambs Posts: 28 |
Great to hear you sorted it l also remember reading in the owner's manual there is a cut out switch in case of collisions so a bad jolt could trigger it
6th May 2021 8:09pm |
