Home > Puma (Tdci) > Interior/Dome Light Fuse for a 2008 Puma 90 XS
Trevor Wright
Can one of you please give me a definitive answer on the correct fuse for the interior/dome light for a 2008 90 XS Puma - the radio is dead as well and the red flash in the instrument cluster associated with the alarm. The Handbook is not too helpful here. Yep - I guess I blew the fuse when trying to install an LED alternative festoon-type bulb... ho hum..
Thanks for your help. Trevor Wright
'08 90 TDCi/TD4 XS SW
Post #894953 30th Mar 2021 4:26pm
Martin
Site Admin
Fuse 30 under the steering wheel, 10 Amp.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #895041 31st Mar 2021 9:05am
Trevor Wright
Thanks - quite correct - all fixed now.
I wonder if there are any recommended LED Festoon replacements which do not have the effect of blowing 10A fuses...? Trevor Wright
Post #895298 1st Apr 2021 10:16am
It's not the bulbs per se. It's the fact that it's so easy to short one out on the large exposed back plate.
On mine, I covered the holes in the plastic chassis with plasticard to blank off the back plates to prevent this:
 Darren
Post #895301 1st Apr 2021 10:22am
