Home > Td5 > Back doors!
excossack
Back doors!
Report post
The rear door on my 1999 TD5 110 is need of replacing
Do I replace with a TD5 door of the same year, a later TD5 or a Puma rear door? Advantages/Disadvantages of either? 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #894861 30th Mar 2021 8:12am
Procta
The later rear doors are steal and a lot more stronger than the earlier doors. Thumbs Up you will need to replace the rear window too/ glass too. Thumbs Up Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Post #894875 30th Mar 2021 9:16am
excossack
Cheers. I did wonder about the glass. 1999 Defender TD5 110
Regards
John M0VAZ
Post #894882 30th Mar 2021 9:52am
Marks Landy
United Kingdom 1985 Defender 90 200 Tdi SW Java Black
I went for a Galvanised steel door from Hairymonsterman (Robert) off eBay.
Very well made and a pleasure to deal with.
Post #894886 30th Mar 2021 10:06am
excossack
Cheers Mark. TD5 style or Puma style? 1999 Defender TD5 110
Regards
John M0VAZ
Post #894888 30th Mar 2021 10:11am
The late TD5/Puma rear doors are much better and, physically at least, a straight swap. I fitted one to my old 200tdi 90:
There's more detail on the fitting here:
https://www.defender2.net/forum/post653755.html#653755
It's worth noting that there's a fundamental difference in the wiring for the rear wiper on post '02 doors, which required a degree of head scratching to resolve. The details of that are here:
https://www.defender2.net/forum/post687685.html#687685
A very worthwhile upgrade, though. Darren
Post #894895 30th Mar 2021 10:38am
Marks Landy
I went for the old style, just swapped over the glass, wiring, wiper and hardware.
Post #894908 30th Mar 2021 11:39am
excossack
Cheers both. 1999 Defender TD5 110
Regards
John M0VAZ
Post #894926 30th Mar 2021 12:36pm
4RF RDS
Canada 2000 Defender 110 Td5 XS CSW Epsom Green
Ditto, put a Puma rear door on my 99 Td5 simple swap and way stronger and better overall. Even sold my old door and covered the cost of the new one 😆 2010 Range Rover MkIII Autobiography Super Charged (Idris)
2003 Range Rover Mk III (Desmond FitzWilliam)
2000 Defender 110 CSW TD5 (CTX)
1992 Range Rover Classic (Lizzy)
1972 Series III 300 Tdi (Stanwood)
1967 MGB GT
Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats.
H. L. Mencken (1880 - 1956)
Post #894936 30th Mar 2021 1:53pm
excossack
I have a swing away rear wheel carrier and I think if I go with a Puma door I will do away with the wheel carrier and stick with the later Puma type. 1999 Defender TD5 110
Regards
John M0VAZ
Post #894939 30th Mar 2021 2:11pm
4RF RDS
No matter how strong the Puma door is it will still stress the door and frame and crack or warp a bit even when a regular sized spare wheel is bolted to it, especially if you off road.
I kept my swing away when I put the Puma door on mine as I off road frequently and do a lot of back road driving. I also put the Nakatenanga upper door closer and strut thingy on. Great combo. 👍🏻https://www.defender2.net/forum/posting.php?mode=editpost&p=894940 2010 Range Rover MkIII Autobiography Super Charged (Idris)
1967 MGB GT
Post #894940 30th Mar 2021 2:17pm
Procta
i always say go for a swing away on these, my old 300 the back door frame be came bent and cracked, due to the weight of the rear spare wheel. laugh was when the car was burnt by two sweet hearts, the door frame held up, but that was after my mate welded it Laughing A later rear door was on the cards at the time, due to the door been practically on its last legs. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Post #896107 6th Apr 2021 12:37am
Slideywindows
[quote="LandRoverAnorak"] I fitted one to my old 200tdi 90:
OT - but that is reassuring Mr Anorak.
I'm not the only one to find it hard to get new paint to match the old! Big Cry
Especially old Arles Blue.....
Post #896242 6th Apr 2021 4:22pm
To be fair, I wasn't trying that hard to get a match as the rest of the vehicle had been hastily reapplied over pink Shocked If it'd kept it longer then I may have re-painted the whole thing with a brush as I was quite pleased with the finish I managed to get on the doors. Darren
Post #896298 6th Apr 2021 6:52pm
Mo Murphy
As did I. An immensly strong door with a galvanised frame and a steel one piece skin. They make the later rear doors look weak ! Also meant I could do away with the swingaway rear spare wheel carrier.
I'm really glad I took this route.
50 Shades of Pennine Grey
Post #897404 11th Apr 2021 12:05pm
