Home > Maintenance & Modifications > New TD5 owner & service cost |
jaygti Member Since: 04 Nov 2012 Location: essex Posts: 378 |
Hi and welcome.
£250 sounds about right to me. I alternate, I do the service myself one year and send it to an independent the next, just to check things over. As for anything else ,if it’s winter and I can’t put it off I’ll send it to the garage, or if I don’t fancy it. Anything else brakes etc I do my self. At the moment they’re all going up in value so they’re worth looking after. 2002 td5 90 county hardtop |
29th Mar 2021 12:47pm |
Adammacky Member Since: 28 Dec 2019 Location: West Midlands Posts: 309 |
Just had a full service on my TD5 110 and it cost £240
29th Mar 2021 6:34pm |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5750 |
When people talk about a full service what does that include?
I would think a full service (according to me) would cost more. But I do new oil in trans box, G box, both diffs, top up swivels, fuel, air, 2x oil filters, and grease all nipples. Possibly brake fluid check/swap, every 2-3 years an injector loom. Then all the checks, and adjustments. |
29th Mar 2021 6:47pm |
HUE Member Since: 29 Mar 2021 Location: S Wales Posts: 4 |
As it turns out, the garage had rang back earlier and it's gonna cost a heck more than that to pass it's MOT in any case! I've no idea why some of the list of things weren't picked up on the last MOT, as the vehicle hasn't done many miles since.
29th Mar 2021 7:55pm |
Landy Andy, exactly what you've just said was included in the full service on mine, its an independent garage I've used for a long time and they're really great guys who do a lot of work on all sorts of landys and range rovers.
29th Mar 2021 8:02pm |
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2666 |
What has it failed on? They’re probably just seeing a new Land Rover owner and seeing a chance to make a quick profit. Service is generally easy to do with simple tools. |
29th Mar 2021 8:31pm |
There was rather a long list of things that was brought up, but have asked for a full breakdown of it so I can check it, but ultimately to get it through its MOT it's probably going to be north of £1500. Namely for brake calipers all round, but then on closer inspection he called again to say that the rear half chassis is not in great condition and has been previously botched welded and then just blasted with underseal to mask it. I have trust in the garage, but that it just going off reviews and recommendations I have seen online, I just can't see how it left the previous garage/dealer in this state and passed its previous MOT, as like I say the vehicle has hardly been driven since. Not sure what to believe at the minute! But doesn't really seem I have much choice, as the type of work they're saying is required is not something I could delve into myself, on most parts anyway. |
1st Apr 2021 7:39am |
Get the fail list and the Def home. Then go through the list, discussing on here if required, and then work what the issues are and what you can do about it, or what you need to get done to it, also with some idea of costs.
1st Apr 2021 8:55am |
So I've had an update this afternoon to say that it's now passed it's MOT after all the work has been done, will be looking to pick up Friday/Saturday, after parting with a smidge under 3k
They have however mentioned that the rear chassis looks corroded in some areas, and have since applied some welding, but doesn't fill me with confidence that it's going to last! I'm usually pretty handy, but replacing something like the rear half chassis is way out of my league. From what I can see, a new one would probably be approx £700, but the labour to fit something like that I would imagine would be quite extensive. |
28th Apr 2021 6:24pm |
familymad Member Since: 13 Dec 2011 Location: Bucks Posts: 3481 |
Ouch 1951 80" S1 2.0
28th Apr 2021 8:29pm |
Beero Member Since: 05 Jan 2021 Location: Southampton Posts: 21 |
Had my 2005 TD5 for 3 months, broken down twice, cost £865 so far and that's without a service or MOT so you're not doing too bad. That's the trouble with old vehicles. I still love it though!
28th Apr 2021 9:39pm |
Procta Member Since: 03 Dec 2016 Location: Sunderland Posts: 5212 |
Time to take it else where, my local garage who my dad used, cost me a nearly £1000, for a timing belt and to do a few odds and sods to pass its mot. They milked the MOT job did they not! anyway that was the very last time my cars went over there. My dad barked about going there still, until they failed his and wanted £1200 to pass it! The funny thing was they failed his on the smoke test. But the car was not in long enough for them to even MOT the car. We took it to the garage that did mine, and it flew through. They could not see why the other garage had failed it on the smoke test, Defender TD5 90 ---/--- Peugeot 306 HDI hatch back Success is 90% Inspiration and 4 minutes Preparation # you can make it! |
29th Apr 2021 4:40am |
