Home > Td5 > Am i going to lose this bolt?
Guinness
Hi there,
I have recently purchased a 2002 td5 defender 110, and for some reason, i am starting to do it up back to front. I want to remove the carpet so i can give it a deep clean, and i need to remove these bolts to remove the carpet i think (the one the flat head is pointing to)?
If i remove this bolt, will the nut end up in the depths of hell or will it be held up? Any advice will be more than welcome!
Thanks,
Josh
Post #893725 24th Mar 2021 10:13pm
htb2
Wales
Captive nut welded into crossmember underneath, will probably be a metric fine thread.
Post #893729 24th Mar 2021 10:23pm
v8bob
United Kingdom 1998 Defender 90 300 Tdi HT Nato Green
If it is a genuine seat belt bolt it will be imperial thread.
Just like every seat belt bolt. Often on new vehicles having imperial thread and metric spanner head.
Thats the full metric version Rolling with laughter
Post #893771 25th Mar 2021 9:47am
7/16" UNF thread, if I recall correctly.
Post #893777 25th Mar 2021 10:02am
miker
I think (though could be mistaken) that on mine it's a nut, welded to a nut plate, riveted to the underfloor supports. SHould stay attached, but one of mine had partially broken free. Either way it's a big obvious lump that you can get to from underneath.
Post #893911 25th Mar 2021 6:03pm
Guinness
Fortunately, it was a captive nut and now my carpet is hanging up drying, the pressure washer did a surprisingly good job on the rust stains!
Post #893955 25th Mar 2021 9:08pm
Procta
give the threads that its going in a check up, and a clean. I had to replace a seatbelt mount on my old 300 TDi, due to this sort of thing, but that was down to the previous owners putting the bolt in on the p!ss, making it a nightmare! Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
In the words of my Good Friend, Gary Forrest 1980 -2025
" we will work something out"
Post #894828 30th Mar 2021 2:11am
