Home > Technical > Replacement UJ sizes |
williamthedog Member Since: 29 Dec 2012 Location: south wales Posts: 3441 |
Why don't you give Gwyn Lewis 4x4 a call. I'm sure he'd be able to help you out
25th Mar 2021 8:28am |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5724 |
Or Bailey Morris who make props, and is where I buy my UJ’s from. They know everything about props in my experience.
https://baileymorris.co.uk/ |
25th Mar 2021 8:33am |
STC4807
prop shaft UJ 93mm---------------- 1A---to----6A---i.e.2001--------------2006 93mm----wide---------------27mm----cup--dia used on prop shaft tvb100610 RTC--3346----prop shaft---UJ---82mm----- wide----27mm---cup--dia to chassis number CA--i.e-1986 TCV100010G----75mm---wide----27mm---cup--dia All Propshafts from 2A638134, except TVB100610 FTC 4198 superseded by tcv100010 75mm wide 27mm cup diameter From CA252579 to 1A612404, Front & Rear props From 7A, Rear prop - 90 only Except Front Propshaft from 7A |
25th Mar 2021 9:50am |
