Home > Maintenance & Modifications > Chequer Plate Alternatives
Pace
United Kingdom 2013 Defender 90 Puma 2.2 XS CSW Santorini Black
I have a 90 that I had planned to fit some brand new Mammoth 3mm wing top plates to, but they have an aerial hole and my vehicle does not have an aerial. I see this as an opportunity to look at doing something different.
I have seen there are some plain plates that are essentially the same as the chequer but without the pattern. Before I press the button on those, are there any alternatives, either in material or style that I should consider?
I know there are plenty of shops selling "stuff" but far more interested in the experiences and opinions on here.
I am only doing the wing tops and whatever it is will need to be black. It is essential that I have surface on which to place my brew, so any alternatives must be capable of withstanding these harsh demands... Laughing
Post #893692 24th Mar 2021 8:39pm
Shroppy
United Kingdom 1986 Defender 130 V8 Petrol HCPU Aintree Green
If its only for a brew then why not rest it on the wingtop vent and do without any chequer plate/protection? Thumbs Up 1985 127 V8 Build Thread
Series 2 109"
Series 1 80"
Post #893706 24th Mar 2021 9:29pm
Badger110
United Kingdom 2011 Defender 110 Puma 2.4 USW Buckingham Blue
Although I don't have an answer for you question, I bought this kit without a hole
https://www.ebay.co.uk/itm/LAND-ROVER-DEFE...2749.l2649
Matches the Mammoth bonnet plate very well.
Post #893712 24th Mar 2021 9:34pm
Pace
A fair question, but it is also likely to be for accessing the roof if/when I get a rack.
Post #893738 24th Mar 2021 11:05pm
Pace
I've seen those, I am not against the idea but I wanted to go a bit more adventurous! I do like them on other people's vehicles, though.
Post #893739 24th Mar 2021 11:07pm
MichaelE
UpRoar 4x4 do something different. I have them, not wanting chequer. Not cheap. The right side has a semi circle where the aerial hole is. I decided against having an aerial there when I did my my respray and blingification so cut a circular filler plate after the aerial was removed.
Post #893747 25th Mar 2021 12:59am
mwestcrew
United Kingdom 2011 Defender 130 Puma 2.4 HCPU Baltic Blue
I’ve got the Equipe4x4 bilayer wingtops. I like them a lot and they fit very well. They do them in all black. 2011 130 Utility Body
2005 110 Van
Post #893749 25th Mar 2021 2:24am
macfrank
Germany 2015 Defender 110 Puma 2.2 SW Keswick Green
If money is not a concern, here are two different styles:
swiss: https://www.rough-parts.com/en/foot-plate-wing-alu
german: https://translate.google.com/translate?sl=...aerkungen/
I wonder if it's possible to glue a reinforcement of some kind to the underside of wing and bonnet?
Post #893905 25th Mar 2021 5:54pm
I'd look carefully how the wings are supported towards the bulkhead and whether they would need strengthening before taking that sort of weight.
I think these guys used to make a bracket, but can't find it on their site:
https://www.nakatanenga.de/en/about-us
Post #894034 26th Mar 2021 8:47am
doncarloz
Austria 2015 Defender 110 Puma 2.2 DCPU Stornoway Grey
Entreq from Germany do a support bracket if you wanna step on your wingtop.
https://entreq.de/produkte/kotfluegelstuetzbleche/ ___________________________________
1993 D1 200 Tdi
2015 110 DCPU 2.2 Tdci
2017 RRS 3.0 TDV6
Post #894108 26th Mar 2021 1:11pm
That's the one ~ no wonder I couldn't find it on the Naks website Thud
Post #894115 26th Mar 2021 1:40pm
Pace
How dare you. Laughing
Fair point, though.
Thanks for all the suggestions, it's almost surprising there are not more versions of this as they're all relatively similar. I am slightly concerned by those bi-layer versions as I can see mud/dust getting into those and being impossible to remove!
I am going to see if I can view those Rough Parts ones in person as they do seem like the kind of thing I'm looking for.
Post #894245 27th Mar 2021 1:27am
Sorry, it does read rather rude!
It was meant to be a comment on the value engineering that has gone into the wings over the years. I certainly wouldn't want anyone standing on my wings without additional support.
Post #894251 27th Mar 2021 7:21am
Pace
I assure that that no offense was taken.
I have owned a Defender of one sort or another for a couple of decades and had no idea there was an issue. Or that a piece of bent plate to address it could cost that much.
Post #894261 27th Mar 2021 8:49am
