Home > In Car Electronics > Tow bar electrics
chris d3
England 2011 Defender 110 Puma 2.2 USW Stornoway Grey
Tow bar electrics
Looking for some advice please I’ve got a 7 pin electrics on the defender and my trailer is 13 pin
What would be best twin plugs with the adapter or just putting the single plug are they just a straight swap TIA
Post #893403 23rd Mar 2021 12:42pm
familymad
Get the adapter plug from 7 to 13. Quick fix 1951 80" S1 2.0
1995 110 300TDI
1995 90 300TDI
Post #893410 23rd Mar 2021 12:57pm
Leamreject
Italy 2011 Defender 90 Puma 2.4 HT Fuji White
You’ll need something like this...
Or this
They do reverse ones also depending on your set up Ride like you stole it!!
If I’m not on a bike it’s because only a 4x4 will do…
2011 2.4 Puma 90 HT
Post #893417 23rd Mar 2021 1:22pm
rallysteve
That top adaptor is the wrong way around (for 13pin vehicle to 7pin trailer).
Do you have both 12N & 12S (black and grey 7pin) sockets on the defender currently?
If you only have the black 12N one then I would just straight swap it for a 13pin socket. The 13 pin system is so much better than the old 7pin ones.
If you have both sockets on the defender it can be slightly more messy to wire both cables into a 13pin socket - still better in my opinion though.
Post #893420 23rd Mar 2021 1:26pm
It shouldn't have a bearing on your solution, but you might want to bear in mind that if you replace the 7-pin socket currently on your Defender with a 13-pin socket, the new socket will be tested as part of the MoT test. Quite wjhat aspects of it are tested, I don't know, but 13-pin sockets are in-scope, 7-pin sockets are not.
Post #893427 23rd Mar 2021 1:43pm
rallysteve
Good point Blackwolf, MOT test should only cover:
Quote:
On vehicles fitted with a trailer 13 pin Euro-socket, use an approved device to check that the socket is wired to correctly operate the trailer:
position lamps
stop lamps
direction indicators
rear fog lamp
So only the functions of the standard 7pin 12N socket.
Post #893434 23rd Mar 2021 2:03pm
chris d3
I’ve got the adapter but will it power the battery charger in the trailer
Post #893569 23rd Mar 2021 10:30pm
If you've only got a single black seven pin 12N socket then no, as the live for that function comes from the grey 12S socket.
If you've got two seven pin sockets and an adapter to convert to 13 pin then yes it will. Darren
Post #893587 24th Mar 2021 6:19am
grafty99
The 13 pin electrics on my 90 have never been tested (I always watch the MOT because I'm sad like that Laughing)
13 pin in my opinion is a far, far superior connector than the 7 N+S setup in every way - more reliable too Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #893943 25th Mar 2021 6:48pm
chris d3
Where’s the best place to get the 13 pin?
Is it a straight swap on the defender
Post #894152 26th Mar 2021 3:46pm
Race.it
Spain 2010 Defender 110 Puma 2.4 SW Alaska White
Brought mine from paddock spares and technically plugged it myself Searching for my first Defender...and started just as Covid hit, so talk about timing.
5 months after starting the search I found it, and here is the details
Post #894168 26th Mar 2021 5:38pm
cradgebank
England 2008 Defender 110 Puma 2.4 XS CSW Stornoway Grey
Think it only became part of the MOT inspection from February 2021. Richard
Either a 90, 110 or 130.
Discovery 5
Post #894248 27th Mar 2021 4:38am
grafty99
Mine was MOTd in March so should have been tested. Would have passed anyway as it all works as it should Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #894575 28th Mar 2021 8:26pm
