Home > Td5 > Electric window RH front stuck open |
GREENI Member Since: 22 Aug 2010 Location: staffs Posts: 10381 |
There may be a couple of 10mm bolts that you can undo if you can get to them, take the window off the runner and push it up...wedge it in.
If you've gone to the length of taking the door card off, you might as well look at the wiring and cut n twist the wire until doing it properly? |
17th Mar 2021 1:24pm |
Dixy Member Since: 30 Nov 2020 Location: Somerset Posts: 51 |
The problem is probably in a wire between door and the body, in the hinge gap. Pull the rubber sheath of (Ooh Matron) and fiddle with the wires whilst pressing the up button.
17th Mar 2021 1:41pm |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6605 |
If you've got the door panel off, 12V + applied to RED, Ground (0V) on BLUE should power the motor up. 1988 90 Td5 NAS soft top
2015 D90 XS SW |
17th Mar 2021 1:47pm |
Gandhi the Landi Member Since: 17 Mar 2021 Location: Meath Posts: 6 |
Cheers, will give these a go and see how I get on. Tks
17th Mar 2021 2:02pm |
All sorted, blue wire was severely chaffed between door and post. Thanks all
17th Mar 2021 2:54pm |
