Home > Td5 > Electric window RH front stuck open
Gandhi the Landi
Ireland 2002 Defender 110 Td5 CSW Epsom Green
Hi, Drivers window has been acting up for the last few weeks. Switch would not work when door was closed but would when open. Then moved to only working when door was half open etc. Sounds like a wire has frayed or something. Immediate problem is the window is open full and no movement. Is there a way to manually close the window until I get someone to have a proper look. Have the inside panel off and have had a quick look at the wiring to no avail. Is there something I can ‘screw’ to close or manually push it up shut? Thanks anyone
TD5 2002 CSW
Post #892072 17th Mar 2021 11:47am
There may be a couple of 10mm bolts that you can undo if you can get to them, take the window off the runner and push it up...wedge it in.
If you've gone to the length of taking the door card off, you might as well look at the wiring and cut n twist the wire until doing it properly?
Post #892098 17th Mar 2021 1:24pm
Dixy
United Kingdom 2007 Defender 90 2.5 TD CSW Cairns Blue
The problem is probably in a wire between door and the body, in the hinge gap. Pull the rubber sheath of (Ooh Matron) and fiddle with the wires whilst pressing the up button.
Post #892102 17th Mar 2021 1:41pm
Martin
Site Admin
If you've got the door panel off, 12V + applied to RED, Ground (0V) on BLUE should power the motor up.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #892104 17th Mar 2021 1:47pm
Gandhi the Landi
Cheers, will give these a go and see how I get on. Tks
Post #892108 17th Mar 2021 2:02pm
Gandhi the Landi
All sorted, blue wire was severely chaffed between door and post. Thanks all
Post #892112 17th Mar 2021 2:54pm
