Home > Maintenance & Modifications > Puma Rear Brake Shields- Replacing
jcw
United Kingdom 2007 Defender 90 Puma 2.4 HT Stornoway Grey
The rear brake shields on my 2.4 Puma are not in the best shape and I’m considering replacing them with new ones.
How much disassembly is required to remove them?
Post #892032 17th Mar 2021 7:38am
jimbo55
If you are on about the shields then I would just remove them, they always get debris stuck between them and the disks.
As for replacement, I think they can be removed in situ so no need to strip it all down and is only 3 bolts holding them in - maybe wrong though as it’s been a few years since I removed mine
Post #892041 17th Mar 2021 9:05am
jcw
Yes sorry, I do mean the shields - not keen on stripping the brake disc / hub etc. so if they can be simply removed by just undoing the mounting bolts that would be ideal - I will probably replace rather then leave off though.
Post #892046 17th Mar 2021 9:51am
Yes, they should just unbolt as far as I recall.
Post #892047 17th Mar 2021 9:52am
jcw
Ah, thanks blackwolf, a bit more involved then, I’ll factor that in to whether I bother Thumbs Up
Post #892048 17th Mar 2021 9:53am
Sorry, my earlier post was wrong, hence my edit, but it wasn't quick enough to stop you reading it! Sorry.
Post #892049 17th Mar 2021 9:56am
Caterham
thanks Blackwolf.
On my to do list - and now since it's an easy job I'll move it up the list Mr. Green
Thumbs Up
Post #892051 17th Mar 2021 9:59am
jcw
Ok, understood, so just the three mounting bolts to remove then - in which case I’ll give it a go and replace with new shields Very Happy
Post #892052 17th Mar 2021 9:59am
Dinnu
Yes, 3 M6 bolts.
One of them has the nut welded to the shield.
The other 2 you need 2 spanners, or a ratchet and spanner or grinder or a plasma cutter. Joking, M6 will shear easily if they are rusted. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #892056 17th Mar 2021 10:30am
Retroanaconda
Don’t remove them unless you do a lot of off roading in very heavy mud. In those conditions they can cause bother by trapping mud/stones as above, but in all other conditions they serve a much more important function of significantly extending brake pad life.
I was going through a set of pads in a month on mine before I put the guards back on.
Post #892063 17th Mar 2021 10:54am
Co1
I took mine of and removed the loose rust, a coat of jenolite and them hammertoe and they are good as new. That was about a year ago and they still look good. It’s a 5 minute job to get them off.
Post #892168 17th Mar 2021 7:28pm
bear100
Ive asked this question before and the consensus was 50 50 for remove or replace
I’m sure there is a stainless version available if memory serves me right 2016 Range Rover Autobiography 4.4 TDV8
2010 110 XS Utility 2.4TDCI
1993 110 csw 200 tdi (gone)
1994 90 HT 300 tdi (gone)
1994 discovery 300tdi (gone)
90 hybrid 3.5 v8 (gone)
Post #892180 17th Mar 2021 7:57pm
Notyalc
United Kingdom 2003 Defender 90 Td5 HT Epsom Green
Cant see why no backplates would make any difference.
I removed mine on a TD5 2 years ago and no difference
Post #892191 17th Mar 2021 8:25pm
Retroanaconda
Because the discs are more exposed to the spray from the front wheels which is laden with grit - particularly if used on unsealed surfaces. If you rarely go off tarmac it won’t make as much difference to pad life.
Post #892192 17th Mar 2021 8:29pm
