Home > Maintenance & Modifications > LED Tail & Indicator Lights |
CFB Member Since: 13 Sep 2007 Location: Bradford, West Yorkshire Posts: 803 |
Look smart, do they do them for the front too? Andy
23rd Mar 2009 7:29pm |
nicks Member Since: 21 Aug 2008 Location: south coast Posts: 469 |
they do, but the standard plinths are too wide for the panel, so i assume they wouldn't sit straight, but saying that i've never tried, i'll give it a go when i get a second
23rd Mar 2009 7:47pm |
mlightfoot Member Since: 10 Jan 2009 Location: Cheshire Posts: 86 |
Nicks - They look amazing where did you get them from and did they require much interms of modification?
I want to get an LED kit but ideally a full set for all lights, like here: http://www.roverantics.com/ Cheers M |
23rd Mar 2009 8:34pm |
kljw Member Since: 23 Jan 2009 Location: Edinburgh Posts: 265 |
mlightfoot
have you tried JE Engineering, they do a LED kit for the diffy. Cheers keith puer claudius |
23rd Mar 2009 9:00pm |
Sonic3d Member Since: 28 Jan 2008 Location: Ross on Wye Posts: 1505 |
Is your reversing light led? and if so is the back face of it flush?
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6613 |
From the appearance, I'd say the reverse and fog are still bulbs.
A company on eBay is (was?) doing modified plinths to mount the larger lamps on the standard holes. |
23rd Mar 2009 9:57pm |
the fog and reverse are still normal lamps, not got around to changing them yet. The back of the lamps come with either a plug or just bare wires.
23rd Mar 2009 10:33pm |
the plinths are just the standard fog/reverse plinths
23rd Mar 2009 10:36pm |
Sorry, I meant that they do the modified plinths for the front
On my 90 I've used the older style (pre-Td5) headlamp finishers, kept the standard plinths (they were all that was available at the time) and modified the body mounting holes and the finishers for the bigger lamps: |
23rd Mar 2009 10:41pm |
Thanks - Where did you get them from?
24th Mar 2009 6:39am |
beetroot Member Since: 15 Dec 2008 Location: manchester Posts: 41 |
I have gone with the clear LED's they come with plugs that fit straight on to the factory loom, and you can get adaptor plinths that mean you dont have to drill new holes in the back body. When Land Rover did the SVX they could not get the indicatiors to work which is why the SVX has led's on the rear except for the indicators which are normal bulbs. People cleverer than Land Rover have now worked it out so you can have all LED's.
Click image to enlarge Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated |
24th Mar 2009 8:38pm |
Can someone please let me know who sells the led reverse led light as i want some to fix to the underside of the rooftent when unfolded to light up the tailgate area
24th Mar 2009 9:26pm |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5038 |
Where did you get the LED units that are a direct replacement? im not sure if i like them, but am tempted. I assume it needs a new relay
I will add though that Land Rover could get the LED indicators but didnt for a few reasons, one like everything on the SVX is compromise 2 is servicability apparently (so you can easily go an get the bits) Mike |
24th Mar 2009 9:31pm |
i can supply the indicators, clear or amber lens' - i prefer the coloured ones. i get them from the manufactuer that supplies us with other led lamp units, so as we buy in bulk we get better discounts. i changed the relay to an electronic one so the indicators flash normally.
24th Mar 2009 10:18pm |
