Home > Td5 > Speedo Wiring |
roel Member Since: 08 Aug 2009 Location: Lelystad Posts: 2039 |
You can download Rave for td5's upto 2002 from severall places on the internet. I have a 2003 td5 and only small things are different. Roel
1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
15th Sep 2011 7:02am |
wslr Member Since: 18 Jul 2010 Location: Wellington, Somerset Posts: 581 |
Pin 13 on the Engine ECU (Black C0658) is linked to the instrument pack by via connector. Yellow/Pink wire.
You've got 4 wires linked between the black ECU plug and the instrument pack - Pins 6, 30, 7 and 13. |
15th Sep 2011 10:39am |
df1 Member Since: 06 Aug 2011 Location: Ireland Posts: 221 |
So it looks like the wire heading to pin 13 on the black plug is coming from the speedo ?
The other 3 mentioned above appear to be output cables ? I'm just having a niggling problem fitting an adaptor to this line in order to operate the cruise control on the defender TD5 with 1.2 ratio transfer gears. |
15th Sep 2011 1:08pm |
