![]() | Home > Faults & Fixes (L663) > Stop / Start not working |
Simon Audi Member Since: 19 Nov 2020 Location: Newport Posts: 544 ![]() ![]() |
Try charging the battery for a day or 2
There is voltage level triggers in all the Start Stop Systems Not saying that is the issue - but a good place to start. |
rafman Member Since: 23 Feb 2021 Location: Perth Posts: 6 ![]() ![]() |
Thanks, I did try charging the battery, but it made no difference. As I mentioned as soon as I turn the a/c off it works fine. D300 HSE - Eiger Grey
L405, Disco 4, RRS all sold. |
Digger2000 Member Since: 19 Sep 2020 Location: Newcastle Posts: 590 ![]() ![]() ![]() |
Get Land Rover assist out.
RDR Member Since: 27 Apr 2018 Location: Derbyshire Posts: 595 ![]() ![]() |
from bitter experience on other models and I can only imagine the Defender is the same in this space. the Stop Start system is way to clever for its own good. From my own problems I know it relies on parameters across the whole battery management system being just right for it to work. It monitors current draw vs battery state and more so the minute something is slightly out of whack it stops working. My dealer spent weeks trying to find a problem on one of my discos. 110 MY23.5 X Dynamic HSE
RR MY23 HSE PHEV D5 MY19 HSE - Now Sold D4 MY16 HSE Luxury - Now Sold D4 MY12 HSE - Gone D3 MY06 S - Gone but not forgotten |
jeffersj Member Since: 23 Jan 2015 Location: Near Preston Posts: 431 ![]() ![]() ![]() |
Evoque batteries were dying on some models after a few months because of the stop start especially on cars only doing short town runs. Save the battery and turn it off! Jeff
Ex 1968 Series 2A Ex 90 TD5 Ex D3 Ex D4 |
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2735 ![]() ![]() |
Consider yourself lucky - most people are trying to find a way to disable the damned thing, yours has done it itself!
J77 Member Since: 04 Nov 2019 Location: Fife Posts: 3461 ![]() ![]() |
It never works during the winter on my velar, due to heating being on, heated seats etc. In the summer it works more unless a really hot day where the aircon is working hard.
To be honest it’s not worth the hassle. 24MY 90 D250 HSE, Tasman Blue |
Q86ARR Member Since: 28 Feb 2017 Location: Earth Posts: 38 ![]() |
Seems like it is working as it should then. AC is a stop start inhibit. If you are requesting cold and it can’t maintain it for 4 minutes without the engine running then it won’t go in to an eco stop |
I don't believe that is how it should work. In my wife's RRS which is almost brand new, same d300 engine, it works perfectly with the A/C on and pretty much every car I've driven in the past few years has also had no problem with it working while the a/c is on. I do understand if for example it was very hot outside and a/c was on max, but even setting a/c to outside temp of 22 degrees (Celsius) and fan speed of 1, it still won't work.
Happy to be corrected if I am however wrong. D300 HSE - Eiger Grey L405, Disco 4, RRS all sold. |
From the manual -
TRIGGERING AN AUTO STOP To trigger an auto stop, drive forward with Drive (D) or Sport (S) selected, and stop the vehicle. Fully press the brake pedal to make sure the vehicle is stationary. The following conditions inhibit an auto stop: The external temperature is less than approximately -4°C. The external temperature is more than approximately 40°C. The engine or other vehicle systems have not reached their optimum operating temperatures. The driver's seat belt is unbuckled. Demand from the climate control system requires the engine to be running, e.g., when in defrost mode. The vehicle's battery charge is low. The auto stop/start system is deactivated. After reversing, the vehicle's speed has not exceeded 16 km/h (10 mph). The instrument panel displays an information lamp when the vehicle is stationary and the auto stop/start system is active, but operation is inhibited. See AUTO STOP/START INHIBIT (WHITE). 24MY 90 D250 HSE, Tasman Blue |
Appreciate all of that, however none of it applies, what does happen is that when you press the brake pedal then the stop/start symbol in the dash comes up in white. As I mentioned as soon as I turn off the a/c it works perfectly. D300 HSE - Eiger Grey
intensityderen Member Since: 03 Jul 2021 Location: Orlando, Florida Posts: 2 ![]() ![]() ![]() |
Same Problem. Picked up my 4 cylinder Defender 110 two months ago. Engine won't stop unless the A/C is off or at 75 degrees F or higher. Salesman has the same one WITH additional rear A/C and his works fine. Service Manager says that's the way it is. Landrover USA says they agree with the dealer. Salesman says maybe a future software update will fix it. I understand that many people don't like it, but I consider it a defect if it doesn't work as specified. Anybody else get a better resolution?
Tim in Scotland Member Since: 23 May 2007 Location: The Land that time forgot Posts: 3753 ![]() ![]() |
Mine has worked faultlessly since delivery last year until the latest update over the air was installed and now it only works occasionally even when all the requirements are met apart from I haven’t been able to check the battery charge. Previous cars with Auto stop start have had a second battery for AS/S but I don’t think L663 has the extra battery. Pangea Green D250 90 HSE with Air Suspension, Off-road Pack, Towing Pack, Black Contrast roof , rear recovery eyes, Front bash plate, Classic flaps all round, extended wheel arch kit and a few bits from PowerfulUK Expel Clear Gloss PPF to come
2020 D240 1st Edition in Pangea Green with Acorn interior. Now gone - old faithful, no mechanical issues whatsoever ever but the leaks and rattles all over the place won’t be missed! |
