Home > Faults & Fixes (L663) > Stop / Start not working
Page 2 of 2 <12
Damo
Evening,
I've got the same problem, apparently needs a wiring harness component, having been told it needed a new wiring loom.
Post #911827 10th Jul 2021 10:04pm
intensityderen
United States 2016 Defender 110 2.5 Petrol HT Auto Cobar Blue
What year is your defender?
Post #911846 11th Jul 2021 2:03am
SSM 75349 - L663 21MY Stop / start functionality Inoperative
There was an SSM for this.
Post #911876 11th Jul 2021 10:29am
Tim in Scotland
The SSM is for the 6 cylinder Petrol engine no mention of the diesels. Pangea Green D250 90 HSE with Air Suspension, Off-road Pack, Towing Pack, Black Contrast roof , rear recovery eyes, Front bash plate, Classic flaps all round, extended wheel arch kit and a few bits from PowerfulUK Expel Clear Gloss PPF to come
2020 D240 1st Edition in Pangea Green with Acorn interior. Now gone - old faithful, no mechanical issues whatsoever ever but the leaks and rattles all over the place won’t be missed!
Post #911878 11th Jul 2021 10:44am
Correct ~ but better to know this than not surely?
Just how much of the software do you think is written from a blank sheet, rather than amended/shared from existing?
Post #911910 11th Jul 2021 1:31pm
SN
My D200 six pot does pick erratic times to do Stop/Start - but I don't really care, I'd probably switch it off if I could bother to find out how to do it (if even possible) - less wear/tear quite frankly, and I do so few miles the impact is basically nothing. Steve N | 21MY Defender | 08MY Discovery 3 (history) | 06MY Discovery 3 (ancient history)
Post #912005 12th Jul 2021 10:42am
abpod
United States
Retroanaconda wrote:
Consider yourself lucky - most people are trying to find a way to disable the damned thing, yours has done it itself!
Mine has not worked since Day 1 which I think I'm ok with - it would probably annoy me if it were on. '21 L663 X-Dyn HSE P400 Carpathian
'13 L319
'03 L322
Post #917768 19th Aug 2021 3:30pm
Shorty53
United Kingdom 2012 Defender 90 Puma 2.2 XS CSW Santorini Black
On my D250 it does not work if the car has rested for a few days and kicks in after a few miles when the battery has recharged. Certainly does not work under any conditions when the a/c is on. Dealer says this is normal.
Post #917887 19th Aug 2021 10:35pm
Hairy Dan
United Kingdom 1998 Defender 90 V8 Petrol 50th Auto Chawton White
I've had my car since last Wednesday and the stop/start hasn't worked up until tonight when for some reason it seems to be functioning as normal now Confused Cheers Ian
22MY Defender 110 D200 SE, Fuji White.
Kielder 4x4 Safari
Instagram @defender_v8
Post #923307 28th Sep 2021 11:29pm
Shorty53
Does it work when the a/c is on?
Post #923334 29th Sep 2021 8:27am
#1784
Sweden
If it judges that cabin climate will be OK even without AC compressor running, so if it's hot or sunny outside stop/start is inhibited so that AC can function.
I've found the system pretty predictable, in all normal cases it functions seamlessly and the re-start is so quick so there is not a noticeable lag in driving away.
If you for some reason want to prevent a stop, it's just to use a light foot on the brake when stopped. The engine stop is only triggered with a fairly firm press on the brake pedal when the car is stationary. 110 SE D200 MY21 Tasman blue
Discovery 3 V8 HSE MY06
Discovery 1 V8 ES MY97
RRC 2-door V8 MY83
Post #923336 29th Sep 2021 8:57am
Shorty53
That's a clever system. Does it know if the cabin is damp, muggy and steamed-up so the a/c acts as a dehumidifier?
Post #923342 29th Sep 2021 9:29am
Tim in Scotland
I concur with #1784 - turn the climate setting to the outside temperature or higher and the stop/start works fine and as designed - select a lower temperature that the fridge compressor starts to work then auto stop/start is inhibited even if the cabin temperature is low enough that the compressor stops running the stop/start will not operate because the outside temperature is higher. Even here in Scotland where it isn’t tropical hot the stop/start will not operate in the summer if the outside temperature is higher than inside the car unless you turn the heater up to match the outside temperature! Only way to get around it is to inhibit the climate control - not great if you are in a city centre on a hot day and want to save the planet from exhaust fumes. Pangea Green D250 90 HSE with Air Suspension, Off-road Pack, Towing Pack, Black Contrast roof , rear recovery eyes, Front bash plate, Classic flaps all round, extended wheel arch kit and a few bits from PowerfulUK Expel Clear Gloss PPF to come
Post #923350 29th Sep 2021 9:58am
Hairy Dan
Last night when it started working I had the ac on (I just leave it on constantly on Auto) the windscreen wipers on and headlamps as it was chucking it down with rain Thumbs Up Cheers Ian
Kielder 4x4 Safari
Post #923416 29th Sep 2021 3:15pm
Gareth
The stop/start system suddenly started working on mine yesterday. 2021 Defender 110 X-Dynamic HSE D300 MHEV
1966 S2a 109 aka Betsy
Post #923420 29th Sep 2021 3:33pm
Page 2 of 2 <12
