Home > Puma (Tdci) > Nanocom for Apple Mac
Page 2 of 2 <12
Badger110
United Kingdom 2011 Defender 110 Puma 2.4 USW Buckingham Blue
Trailbear, your Mac is built to run windows as a secondary operating system, the tools to do so are on your Mac already, it just takes a little reading and some very simple steps to do it.
Once done, you will turn the Mac on and be greeted with a fully functioning Windows system laptop, no dodgy copies of windows needed, it's free.
You can swap between Windows and the Mac OS very easily, so don't be put off by thinking you've lost the Mac abilities, you haven't.
Once installed, your Mac will act 100% like a windows laptop.
You can do this by following either of these links or get someone to sit with you whilst you do it Wink
For windows 7 install
https://support.microsoft.com/en-us/topic/...21eb58ec6f
For windows 10 install
https://support.apple.com/en-gb/HT201468
Here's a video showing the process;
I've used Windows machines for nearly 20 years and only now do I use Macs as it's just easier and if I need a windows program, I just swap over on the MacBook, it's the best of both worlds imho.
Post #889478 6th Mar 2021 6:39pm
trailbear
Right, I’m gonna give it a go, one question though, should I use windows 7 or 10?
Post #889508 6th Mar 2021 7:59pm
macfrank
Germany 2015 Defender 110 Puma 2.2 SW Keswick Green
-del-
Post #889514 6th Mar 2021 8:33pm
Balvaig
Cannot advise on which version of Windows to use, but do make certain you have a time machine backup of your Mac before you start.
Not intended to put you off, just safety first.
Bootcamp really is simple to do.
Post #889520 6th Mar 2021 8:54pm
Badger110
It does depend on which version the Nanocom prefers to run on? If you want to do this for just this program then go with what it is suited too.
Win 7 will use a lot less space ( I think it's 16gb ) over windows 10 ( I believe mine is 48gb to include space for updates )
Balvaig's point about back up is good too.
Post #889545 6th Mar 2021 10:19pm
trailbear
Once again, thanks Gentlemen.
Post #889556 6th Mar 2021 11:35pm
trailbear
Yep, well that’s not good, my Mac with it being new apparently comes with apples own processor
Which doesn’t support Windows....brilliant.
Post #890427 10th Mar 2021 12:41pm
Balvaig
The wonders of modern technology Big Cry You are correct, and it also appears that programmes like Parallels also do not work at the moment with this new processor.
Technology was supposed to make life easier and better.
Most of the new Defender problems appearing in the forum seem to be technology based.
Never had these problems with my Morris 1000.
Post #890442 10th Mar 2021 1:34pm
trailbear
So frustrating but I never gave it a thought that it may not work with a Mac, seems to be
a rather expensive limited bit of equipment for me😫
Post #890518 10th Mar 2021 7:11pm
Page 2 of 2 <12
