Home > Technical > MT 82 Puma Gearbox Issues
SRTDefender
United Kingdom 2008 Defender 90 Puma 2.4 HT Corris Grey
Hello all,
we have been trying to fix a gearbox issue.
During the snow the pipe to the clutch slave fell off resulting in the clutch not working. as a result got the truck home by rev matching.
This then resulted in it becoming stuck in 1st gear. Tried to resolve by removing the dent plugs and sliding the selector rail forward but no luck.
We have since removed and split the box which showed the selector fork to be out of line. Can now select 1st to 6th no problem.
However cant select reverse. any ideas?
Gear box is current out of the truck.
Post #889205 5th Mar 2021 10:59am
Dinnu
What do you mean by selector fork out of line?
Do you mean part 10 with the opening where the gear stick is mounted on part 1 in attached drawing?
https://www.lrworkshop.com/diagrams/land-r...ange_45150
I happened to remove the gear stick on a Puma for maintenance, and noticed that the selector shaft was also more to the left compared to the opening. But I would say that in my case, it would possibly affect 5th and 6th, not reverse. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #889214 5th Mar 2021 11:32am
SRTDefender
garage just said it was out of line put it back and could now select forward gears but now wont select reverse.
Post #889242 5th Mar 2021 2:09pm
Unfortunately without more (and more specific) information it will be almost impossible to offer useful advice, just to say the "selector fork was out of line" is too vague, for a start there are four "selector forks" in the MT82.
The gear selection mechanism in the MT82 is fairly complex, certainly when compared to earlier boxes, and is relatively fragile, so it is possible that something has become bent. I wouldn't have thought it would too difficult to diagnose if you have the dismantled box in front of you though. You are clearly using a garage not doing it yourself, from what you've written, and they should be able to sort it out.
If you haven't already done so, you might want to check out forum member Gloucesternige's videos here and here.
Post #889258 5th Mar 2021 4:35pm
