Home > General & Technical (L663) > Ignition Live Feed for Dashcam
disco_matt
Hi
Having received my Defender on Monday / Tuesday (depending on whether you count paying for it on Monday or getting it on Tuesday counts) I'm now looking at the right way to power a dashcam and other hidden goodies off an ignition live feed.
Does anyone have any experience of locating such a thing - so far my indy hasn't had much luck in identifying a feed which isn't permanent live in a useful location?
Thanks,
Matt
Post #888881 3rd Mar 2021 8:20pm
Scrumps
United Kingdom 2005 Defender 90 Td5 CSW Cairns Blue
Matt,
You can either buy the “new” LR Dashcam kit or you can get a 12v or USB tap from the overhead console from powerfuluk.
Scrumps 90 D250 HSE Tasman Blue
24MY L461 RRS Verasine Blue
05 TD5 90 CSW Cairns Blue
1967 MGB BRG
1944 Willy’s MB OD green
1942 Willy’s MB OD green
Post #888890 3rd Mar 2021 8:46pm
disco_matt
Hey Scrumps
I did take a look at those taps from powerfuluk but they are also permanent live so it doesn't solve the issue of the battery being drained.
Unless I can find an ignition live, it's looking like I need to find a tap which is voltage sensitive, switching off when the voltage gets too low.
Thanks,
Matt
Post #888895 3rd Mar 2021 9:07pm
Scrumps
Matt,
Piggy back fuse off the passenger fuse box?
Fuse 50 if HUD not fitted?
https://www.ownerinfo.landrover.com/docume...c/G2732469
1967 MGB BRG
Post #888905 3rd Mar 2021 10:00pm
deaston
In my Velar I just ran a long USB to the socket in the rear (and hid the cable, of course).
Post #888944 4th Mar 2021 8:19am
SN
^^^ Same in my Discovery 3 - permanent feed is not an issue if you have an in-line 'voltage monitor' which will chop the power if the source voltage (from battery) drops below a certain level. My old Blackvue (and I assume all new ones are the same) has a parking mode enabled by lack of movement from G sensor and which allegedly is lower power usage anyway and it only captures footage if triggered by external movements Steve N | 21MY Defender | 08MY Discovery 3 (history) | 06MY Discovery 3 (ancient history)
Post #888960 4th Mar 2021 9:14am
deaston
The USBs in the Velar were not permanent - they'd go off with the ignition, so ideal for a dashcam.
I can't say I've tried in the Defender, but I would assume it's the same.
Post #888964 4th Mar 2021 9:34am
disco_matt
We've ended up using a spared fused output from the fusebox. It turns off a few minutes after the car has shutdown - thanks for all your suggestions.
Post #888976 4th Mar 2021 10:45am
