![]() | Home > General & Technical (L663) > Odd 90 question ... passenger window |
Scrumps Member Since: 24 Feb 2021 Location: Somerset Posts: 108 ![]() ![]() ![]() |
Tim,
I posted the link to the owners handbook (which contains the same information as the iGUIDE) earlier. Vern said he found a different reset procedure via Google - that is the link I requested. Scrumps 90 D250 HSE Tasman Blue 24MY L461 RRS Verasine Blue 05 TD5 90 CSW Cairns Blue 1967 MGB BRG 1944 Willy’s MB OD green 1942 Willy’s MB OD green |
Vern Member Since: 04 Feb 2021 Location: England Posts: 38 ![]() ![]() |
So it was something like below .. but you have to listen for click but like I say worked and then didn’t lol ...
The windows need to be reset if the battery is disconnected, becomes discharged, or the power supply is interrupted. Once the power supply is restored, reset the windows as follows: Close the window fully. Release the switch, then lift it to the close position. Hold for 2 seconds. Release the switch. Repeat the lift and release procedure twice more. Test the window for correct manual and automatic switch operation. See ELECTRIC WINDOWS. Repeat the procedure on each window. |
So to update the 90 went in today for a couple of bits and they reset the window modules so both windows now go all the way into the casings so job done
J77 Member Since: 04 Nov 2019 Location: Fife Posts: 3425 ![]() ![]() |
I think I’ll need to do this with mine, just a tiny bit sticks up. 24MY 90 D250 HSE, Tasman Blue
