Home > General & Technical (L663) > Odd 90 question ... passenger window
Vern
Hi
Not had a Land Rover before so not sure if a quirk but on our new 90 P300 the passenger window doesn’t go down all the way into the door .. flush near the mirror and it sticks up about the 2cm towards the rear..The drivers goes flush. My family also have a 110 and that front passenger window goes all the way down.
I asked the dealer to check the demo 90 in the showroom and the passenger window was the same as ours so it’s not a fault I just wondered if other peoples 90s are the same or if someone knew the reason why?
Post #887998 26th Feb 2021 6:29pm
Scrumps
United Kingdom 2005 Defender 90 Td5 CSW Cairns Blue
Hi Vern,
Have you tried the window reset procedure just in case it’s not been done since build or part of QA/PDI?
https://www.ownerinfo.landrover.com/docume...c/G2260999
Scrumps 90 D250 HSE Tasman Blue
24MY L461 RRS Verasine Blue
05 TD5 90 CSW Cairns Blue
1967 MGB BRG
1944 Willy’s MB OD green
1942 Willy’s MB OD green
Post #888009 26th Feb 2021 7:23pm
lohr500
Doesn't sound right to me and I suspect the dealer is trying to avoid an issue.
If the window goes all the way down on the driver's side, why wouldn't it do the same on the passenger side. I suspect the window mechanism hasn't been fitted correctly.
Post #888023 26th Feb 2021 8:41pm
Digger2000
United Kingdom 2006 Defender 90 Other HT Tonga Green
I will check mine tomorrow and let you know
Post #888047 27th Feb 2021 12:24am
Vern
Scrumps wrote:
Hi Vern,
Scrumps
Thanks .. given it a go but not worked sadly
Post #888118 27th Feb 2021 2:32pm
Vern
Thanks it’s very odd
Post #888119 27th Feb 2021 2:32pm
Vern
Post #888120 27th Feb 2021 2:35pm
Scrumps
Vern,
I’ll get them to check SWMBO’s @ PDI next week.
1967 MGB BRG
Post #888121 27th Feb 2021 2:41pm
Digger2000
Both right and left are identical, there is about a centimetre that sticks up.
Post #888125 27th Feb 2021 3:01pm
lohr500
Suspect yours aren't 100% adjusted as well Digger2000. Either that or its JLRs way of discouraging you from driving with your elbow out of the window Crying or Very sad
Post #888128 27th Feb 2021 3:13pm
Digger2000
I’ll live with it they are the same as my bmw and these doors are thick doesn’t cause a problem with my elbows. Got to remember the 110 has a smaller window the doors are longer on the 90 and the window tapers toward the rear of the car same as the roof line.
Post #888129 27th Feb 2021 3:20pm
Vern
Hi thanks .. at least we are not alone .. oddly ours is just passenger .. like you might not mess.
Post #888134 27th Feb 2021 3:45pm
Vern
So .. as it was bugging me a tried the window reset that is in the e Manual again and nothing .. so I googled and there are other more complex resetting procedures.. that involve listening for a click. Tried loads and it worked ... window went all the way down .. very chuffed with myself .. turned car off and on again and and it had gone back to sticking up a bit Big Cry
Having seen the window go all the way down now I’m even more annoyed Laughing
Post #888259 28th Feb 2021 10:11am
Scrumps
Vern,
Can you post the link to the procedure please?
1967 MGB BRG
Post #888261 28th Feb 2021 10:28am
DSL
And next time you get the window all the way down, for goodness sake take a pic otherwise the dealer will say “but they all do that, sir”. Whistle Whistle
Post #888262 28th Feb 2021 10:30am
