- You are currently viewing DEFENDER2.NET as a guest - Register to take part or Log In
Vitesse
Helpful tip if anyone has a similar issue....
I found recently that the carpet on the side of the battery box was wet near where it meets with side sill. I investigated and eventually found that water was dripping at the bottom of the door card. I tested by running some water down the window glass.
I removed the door card and sure enough there was a gap of about 2cm where the moisture cover had become detached allowing water to drip down outside of the door structure and thereby dripped on the carpet when closed.
I found that heating up area with a hair dryer softened the factory adhesive and I was able to successfully stick the moisture protection sheet back in position.
Leak cured! 2015 90 XS Santorini Black
9th Feb 2021 12:18pm |
lonewolf
Good tip
9th Feb 2021 2:56pm |
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
