Home > Puma (Tdci) > 2015 Puma water ingress
Vitesse
Helpful tip if anyone has a similar issue....
I found recently that the carpet on the side of the battery box was wet near where it meets with side sill. I investigated and eventually found that water was dripping at the bottom of the door card. I tested by running some water down the window glass.
I removed the door card and sure enough there was a gap of about 2cm where the moisture cover had become detached allowing water to drip down outside of the door structure and thereby dripped on the carpet when closed.
I found that heating up area with a hair dryer softened the factory adhesive and I was able to successfully stick the moisture protection sheet back in position.
Leak cured! Thumbs Up 2015 90 XS Santorini Black
Post #884131 9th Feb 2021 1:18pm
lonewolf
United Kingdom 2010 Defender 90 Puma 2.4 CSW Zambezi Silver
Good tip Thumbs Up
Post #884162 9th Feb 2021 3:56pm
Fellrunner
 2015 Defender 110 Puma 2.2 SW Corris Grey
Thanks for this. I’ve got a minor leak in my 64 plate passenger footwell and have been struggling to work out where it’s coming from. I’ll give this a try.
Post #884171 9th Feb 2021 4:36pm
