Home > Tdi > 300 Tdi into Td5?
JohnPaynter
United Kingdom 2001 Defender 90 Td5 HT Oslo Blue
300 Tdi into Td5?
I have a 51 plate Td5 that has been wrecked on a site by kids. It must have been made early 2002 because it has the 2002 upgraded center console and other upgrades...
The engine doesn't run although it cranks very healthily....tried most things to get it going but eventually gave up
I'm thinking of swapping it for a 300Tdi as I prefer them for usable torque, throttle response and general fun. A td5 can be fast but with the amount of issues with electrics with em Id prefer a 300tdi. I would still like to keep the td5 dash and center console and so on as I like them compared to 300tdi ones....will i be able to simply hitch up a 300tdi to the r380? anyone know whats involved in doing a conversion like this as i don't really have a clue...any info would be useful.
MT
Post #884098 9th Feb 2021 9:40am
I think that mechanically it'd be relatively straightforward (new engine mounts, I guess) but electrically it'll be more involved as the gauges and warning lights are operated quite differently. It's not insurmountable though. I suspect that site owner, Martin, may be able to help with some electrickery to bridge the gap between the two. Darren
Post #884103 9th Feb 2021 10:01am
kenzle8a
Why no go for an M57 conversion, ok its a bit more cost but its going to be far better for fun.
Post #884104 9th Feb 2021 10:08am
JohnPaynter
Yes i thought it would be ok mechanically but any to do with electrics and td5s is going to be complicated.
I have wondered about an M57 and tbh they aren't much more expensive but I've not found substantial information on them, i know a guy called Liam started a YouTube series on it...did it in much detail which is useful but he's stopped the series now for some reason and all the technical stuff like wiring and ancillaries he hasn't got onto, he's stopped dead at getting the engine in, so all the techy stuff that i would want to find out first I haven't found enough research
I thought a 300tdi would be simpler as they need hardly anything to get them going.
Post #884107 9th Feb 2021 10:22am
kenzle8a
MW Machines 4x4 on Facebook do all the parts, Marcus is the man to speak to. NAF Offroad did one as well (hes on instagram).
Post #884117 9th Feb 2021 11:15am
Retroanaconda
The only gauge that has anything to do with the ECU is the temperature, and that can be worked around by modifying the gauge loom to utilise the built-in functionality in the Td5 speedo head to drive a 300Tdi temperature sender. The rest of the electrics don’t really talk to the ECU other than a few bits around the starter/immobiliser etc. and can all be worked around.
Land Rover made 300Tdi-equipped vehicles up until 2006 and the later ones of these of course had the Td5 dash etc. so it’s all either available or can be modified with relative ease.
As much as I love a good Tdi I would just swap another Td5 out of a scrap Disco though.
Post #884152 9th Feb 2021 2:03pm
JohnPaynter
Ok thats very helpful exact info i wanted to know so thanks retroanaconda 👍
Post #884159 9th Feb 2021 2:41pm
Will@LRW
 1997 Defender 110 300 Tdi CSW Alpine White
Another thing is the bellhousing and gearbox input shaft are different, so may be easier to buy a 300Tdi R380 LR Workshop
Find a Defender's history and spec: https://defender.lrworkshop.com
Post #884260 9th Feb 2021 8:12pm
