Home > Technical > Central locking module
kinchjet
2012 Defender 90 Puma 2.2 HT Blenheim Silver
Hi i need some advise please,
I have a 2012 Puma, and am fitting central locking using the OEM actuators (wiring was already there)
the system is all installed but not working
The car originally had the old style key fob, but it was stolen with original keys ( and recovered) in 2016 ,and when i got it back from repairs it had the new style fobs supplied to operate the alarm
question is what type of control unit is likely to be fitted now and can you program the new style control if that was changed when the keys were replaced ?
how can i find out which unit i have , and what options do i have to get CL working
many thanks
Post #884061 8th Feb 2021 11:12pm
s55shh
if you have the new type fobs, then you will have the later spec black ALM module (part number starts with a DH not a CH) look behind drivers speaker. These can be programmed to do central locking but finding someone competent can be interesting.
Post #884121 9th Feb 2021 11:46am
kinchjet
Ive confirmed the Part number begins with DH12 -15K
do i have to get the main dealer to code it for CL or can an independant do this ?
Post #887020 21st Feb 2021 8:06pm
AlexCW
United Kingdom 2013 Defender 110 Puma 2.2 HT Galway Green
My Puma is a 2013 with the key with the chrome strip which I believe yours will be? I had a nightmare trying to get a key coded as no independents have the software (one mentioned Land Rover want £10 000 for the licence, not sure how true that is) and in the end, had to go to a main dealer as they're the only ones with the software to do anything with the later immobiliser (2013-2016).
Alex Alex
2013 2.2 TDCi Puma Hard Top
https://www.defender2.net/forum/topic72473.html
Post #887034 21st Feb 2021 9:13pm
kinchjet
Thanks Alex]
yes i have the chrome strip keys .will talk to my dealer tomorrow
KR
Paul
Post #887037 21st Feb 2021 9:35pm
s55shh
LRC4x4 in Congleton have the main dealer software to access the ALM modules.
Post #887064 22nd Feb 2021 9:50am
Julie
France 2012 Defender 110 Puma 2.2 SW Keswick Green
Blackbox claim the Nanocom to do this job. In this case, it seems to be just à few hundred bucks...
Post #887146 22nd Feb 2021 6:16pm
nitram17
Im not sure the nancom can access the my2015 onward alarm system........others might know better?
Post #887206 22nd Feb 2021 10:50pm
Julie
Well, then - just look on their website
Otters won’t know better than they do
Post #887233 23rd Feb 2021 8:07am
Race.it
Spain 2010 Defender 110 Puma 2.4 SW Alaska White
Thought there was an update recently that meant they could access the later model alarm system. Searching for my first Defender...and started just as Covid hit, so talk about timing.
5 months after starting the search I found it, and here is the details
Post #887255 23rd Feb 2021 10:08am
derbywill
England 2005 Defender 90 Td5 XS CSW Java Black
I think the ALM unit is part of the 1.36 beta Nanocom software, I'm not sure what it can do tho.
Will 2005 90 XS
1954 86'' Series 1 tilt
1968 88” 2A 200tdi
2002 110 Hardtop
Post #887274 23rd Feb 2021 12:23pm
Ianh
See nanocom site, at bottom click on ALM section https://www.nanocom-diagnostics.com/produc...-24-22-kit
Reading the documents I’m no more enlightened as to whether you can enable central locking on the ALM module with the puma 2.4/ 2.2 software.
They have a contacts page where you can highlight your specific requirements and they will be able to advise if the nanocom can do it, what version you will need and the steps to follow if it can. https://www.nanocom-diagnostics.com/contact
If it can do what you want it may be cost effective to purchase via one of the group buys as it provides so many other benefits. Alternatively reach out to members on here that have one locally with the 2.4/2.2 puma software.
Post #887279 23rd Feb 2021 12:41pm
nitram17
Others won’t know better than they do
The website clearly states what the nancom will do regarding the alarm a d key fob settings for pre my2015 defenders....but it is a little hazy on the my2015 defenders.. .... If anybody on here has a My2015 defender and uses the nancom to access the alarm mode I would be very surprised but would purchase one the next day.
Post #887287 23rd Feb 2021 1:30pm
