Home > Maintenance & Modifications > DCPU Spare Wheel Carrier |
Roy5695 Member Since: 15 Feb 2014 Location: Cornwall Posts: 1123 |
I’ll see if I can find it and get back to you it’s been a while since I’ve seen it. I had the spare on the roof for a few years before fitting the wheel carrier. It’ll be in the shed somewhere. 2011 Defender DCPU 2.2 - https://www.defender2.net/forum/topic30623.html
Instagram - @r22oyp Roy |
7th Feb 2021 11:11pm |
steve E Member Since: 06 Mar 2011 Location: Tenby Posts: 2073 |
Many Thanks Roy
8th Feb 2021 7:25am |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17352 |
That is exactly what mine came with (my spacer is steel, not aluminium though, and I suspect that yours probably is too). I have sometimes wondered what is the purpose of the two slots in the disc, any idea?
I have also removed the bits fixed to the bulkhead since they stick out far enough to be a real nuisance if you don't use them for the wheel. |
8th Feb 2021 11:49am |
I'll stand corrected on the spacer ~ it's a while since I last handed it and jumped to the assumption from my photos
No idea about the slots ~ another LR mystery? |
8th Feb 2021 12:42pm |
Thanks guys
At least I know what it looks like 👍 |
8th Feb 2021 1:32pm |
If you have alloys you don’t get the spacer. And it was indeed a spare locking wheel but holding the wheel in, not a wing nut. That was on my roof wheel mount. 2011 Defender DCPU 2.2 - https://www.defender2.net/forum/topic30623.html
8th Feb 2021 5:50pm |
astroarcadia Member Since: 12 Jun 2020 Location: Gloucestershire Posts: 49 |
I have one taken off my 90PU.
PM me if you want it. |
12th Feb 2021 8:43pm |
By that I mean there threaded bar with mounting plate, the retaining disk and the spacer. The nut is just a standard nut.
12th Feb 2021 8:47pm |
What do you mean by "mounting plate", in my DCPU what I would call a mounting plate is riveted in.?
13th Feb 2021 6:35am |
Yea there should be a bit riveted to the rear bulkhead. Tucks up under the capping. The rusty bit in my photo.
Click image to enlarge 2011 Defender DCPU 2.2 - https://www.defender2.net/forum/topic30623.html Instagram - @r22oyp Roy |
13th Feb 2021 8:53am |
Mine was rivetted in too, until I drilled out the rivets and removed the thing. It stuck out too far.
13th Feb 2021 9:03am |
Exactly what I did before the Line-x coating went in. No more pointy bit sticking out at the back for the dogs to hurt themselves on. Also beans anything I carry in the back can sit flush against the bulkhead. 2011 Defender DCPU 2.2 - https://www.defender2.net/forum/topic30623.html
13th Feb 2021 9:06am |
I have this spare and going free.......
Click image to enlarge |
13th Feb 2021 10:42am |
Yes the mounting plate is riveted in. I drilled mine out as I converted my PU to a soft top and now mount spare on swing away arm. |
13th Feb 2021 10:43am |
