![]() | Home > Maintenance & Modifications > Windscreen brackets |
Do you intend to paint them? If so, it probably doesn't matter. The problem with the Optimill ones will be their surface finish rather than the material itself. Darren
Litch Member Since: 10 Mar 2013 Location: Oxfordshire Posts: 765 ![]() ![]() |
I have had a pair of Britpart silver anodised ones on mine since 2013 and they are still in perfect condition.
My original hinge type were fine with no corrosion showing through after many years. I then fitted the later (solid) type and they corroded after only a few years, they were repainted and again only lasted a couple of years before corrosion started to bubble through. Fitted the BP anodised ones in 2013 (to go with my galvanised bulkhead) and they are still perfect. ONE LIFE, GET IT! |
Fat Cog Member Since: 19 Mar 2012 Location: Oxfordshire & Devon Posts: 502 ![]() ![]() ![]() |
PM Huttopia forum member, his windscreen CNC blocks which he sells are rather splendid & great VFM.
![]() Click image to enlarge Since 1973...S1, Air Portable's, Defender's, but only my Wolf TUL HS GS remains |
Sulisuli Member Since: 30 Oct 2016 Location: South west Posts: 4801 ![]() ![]() ![]() |
I think Huttopia has now stopped making his ones. 2015 HT XS 90
2008 SVX 90 2000 XS TD5 90 |
JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7920 ![]() ![]() ![]() |
Having my Huttopia painted and fitted this week! Lovely quality and like the OEM look.
![]() MY2012 110 2.2TDCi XS SW Orkney Grey - http://www.defender2.net/forum/topic43410.html MY1990 110 200TDi SW beautifully faded Portofino Red - https://www.defender2.net/forum/post743641.html#743641 MY1984 90 V8 Slate Grey - https://www.defender2.net/forum/post744557.html#744557 Instagram @suffolk_rovers |
Huttopia's blocks are really nice - I have a set myself - but they are just billet aluminium, the same as the Britpart ones and probably others, too. As long as they're properly coated and the bolts screwed into them also treated with some sort of isolator such as Duralac or other anti-seize paste, then they should be fine. Darren
nitram17 Member Since: 09 Jun 2014 Location: newcastle Posts: 2261 ![]() |
# yrms are great but shiny ..my truck is black and im going for the blck and shiny silver look.... |
