Home > Puma (Tdci) > Starting issue - presumed glow plug related
DG123
Hi all, just wondered if anyone had the same starting issue. With this cold weather, Puma has been firing OK, but then revs immediately dip (sometimes cutting out). I scanned for DTC’s and got the following 3 x glow plug circuitry faults:
P06B9 Cylinder 1 Glow Plug Circuit Range/Performance
P06BA Cylinder 2 Glow Plug Circuit Range/Performance
P06BB Cylinder 3 Glow Plug Circuit Range/Performance
Anyone seen these before? Is this likely to be an actual glow plug issue, or something associated e.g fuse, wiring, relay etc. Could these codes be caused by a less than perfect battery (seems OK, but I think it is the original). Vehicle is 2012 2.2 with 85,000 miles.
Thanks in advance for any help/suggestions. 2012 110 XS SW Orkney Grey
2003 D2 Td5 Black [SOLD]
Post #881840 29th Jan 2021 9:47pm
Do you leave the glow plugs on for a full cycle before starting? How long is the light in the cab on for on each cycle?
The glow plugs should operate during the warm up phase, so there's a few things to check there.
Post #881880 30th Jan 2021 8:20am
DG123
Hi Supacat,
Yes, leave the glow plugs to cycle as per normal till the light goes out. Has only been an issue in this recent cold snap, when it’s warmer I don’t have a problem.
I suspected a main battery issue, hence got the scanner out, but got these permanent circuit/range performance DTC’s. Don’t want to splash out big money for battery if it’s not this issue. 2012 110 XS SW Orkney Grey
Post #881887 30th Jan 2021 9:15am
Dinnu
The 2.2 has a control module that powers each heater plug individually and I think can detect when any one or more of the heaters are not working. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #881889 30th Jan 2021 9:20am
landy andy
I don’t think failing, or failed glow plugs would cause a “dip in revs”. I’m sure I’ve read, on here something else, possibly temp sensor that causes dip in revs after starting.
Post #881890 30th Jan 2021 9:20am
landy andy
Loads of info via the search that may help, or confuse. But most pointing to VCV or camshaft sensor.
https://www.defender2.net/forum/topic73607...p;start=15
Post #881892 30th Jan 2021 10:02am
Check the harness first:
Could do if after glow is not functioning?
Could be:
Post #881897 30th Jan 2021 10:28am
DG123
Hi all, thanks for your help so far.
Landy Andy - reading those posts about VCV seems a similarish fault, but would failing VCV produce glow plug DTC’s? Engine is fine when it starts (and starts OK when it’s not freezing)
Supacat - thanks for all that info. I’m going to have a look tomorrow at the wiring when this icy wind lets up. The DTC’s are permanent; I can clear them but once it goes through a start up, they return (even when engine is warmed up). 2012 110 XS SW Orkney Grey
Post #881981 30th Jan 2021 5:50pm
landy andy
I was thinking that errors may show for the glow plugs because the engine is stalling during their operation. In my experience glow plugs work or they don’t. They aren’t “smart” things, but obviously sensors that control them are these days. And once a diesel is started it wouldn’t stall or alter the revs of an engine, by stopping operation of the glow plugs, again, possibly the sensors associated with them, but not the glow plugs themselves. Think of diesels that don’t have glow plugs.
Post #882016 30th Jan 2021 8:23pm
DG123
Cheers Landy Andy, some good points. I’ve at least got some things to work on 🤞🏻 2012 110 XS SW Orkney Grey
Post #882074 30th Jan 2021 11:44pm
