Home > Td5 > Remap Suggestions |
Notyalc Member Since: 27 Jul 2018 Location: Northumberland Posts: 159 |
Pete bell at Bas, intercooler and hose kit while you are on, and get shot of the egr.
29th Jan 2021 6:42pm |
Fabio Member Since: 05 Aug 2011 Location: Somerset Posts: 589 |
I would always recommend TD5inside/power inside.
I’ve had my defender 2.4 remapped by Jose for about 6 years 70000miles. Fábio |
29th Jan 2021 7:04pm |
Zed Member Since: 07 Oct 2017 Location: In the woods Posts: 3256 |
TD5inside. WARNING.
This post may contain sarcasm. |
29th Jan 2021 7:08pm |
sharkey964 Member Since: 05 Oct 2014 Location: On a muddy track Posts: 574 |
Alive,for me.
Marc |
29th Jan 2021 7:54pm |
Lwb97 Member Since: 10 Sep 2015 Location: Powys Posts: 75 |
Alive tuning
29th Jan 2021 7:56pm |
Inguz Member Since: 06 Sep 2020 Location: In the wild Posts: 101 |
Thanks for the suggestions. Out of the ones mentioned, TD5insides' website isn't functioning, BAS only have a 3-month warranty on their turbos and require evidence of expert fitting, Alive look like a good option. Has anyone used Alives' turbos or intercoolers?
29th Jan 2021 8:38pm |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5666 |
Any of the above mentioned companies would, I believe do a good job.
But would you really want a massively tuned vehicle with a non standard turbo on for overlanding? I wouldn’t. When I used to overland a bit I just had a very basic stage one, and keep it simple. On that note some of the tuners now do kit so you can check, remove, and reinstall tunes, that could be useful for overlanding. I’ve run a BAS tune, several Alive tunes, and the massive Alive intercooler in the past. No problems with any of them. |
29th Jan 2021 8:52pm |
I’m only planning a stage one or two. The turbo needs to be replaced anyways so I was thinking why not upgrade. I was looking at them plug and play kits and they do look interesting but I don’t think they work with my ECU. I suppose I could upgrade the ECU.
29th Jan 2021 9:02pm |
4RF RDS Member Since: 19 Jul 2015 Location: Ottawa Posts: 930 |
The 99 is a MSR ECU non flashable. You can install an NNN ECU and be done with it but you need to ask yourself is it worth it? If as you say you need a new Turbo perhaps it is time to upgrade everything. I have a MSR upgraded stage one and it is great for what I do. I have put 50k Kms on my stage one and I still have everything OEM from factory with 170K Kms on my 99 110.
I do not believe you will need anything more than a stage one for what you are going to do with your 110 for years to come. The question you need to ask yourself is , shall I pay a bucket load of coin on upgrades I may not need or use, or shall I spend a small bit on upgrades I will use every day. Good luck. 2010 Range Rover MkIII Autobiography Super Charged (Idris) 2003 Range Rover Mk III (Desmond FitzWilliam) 2000 Defender 110 CSW TD5 (CTX) 1992 Range Rover Classic (Lizzy) 1972 Series III 300 Tdi (Stanwood) 1967 MGB GT Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken (1880 - 1956) |
30th Jan 2021 2:58am |
PCM Member Since: 25 Jan 2019 Location: North East Posts: 868 |
Another vote for Pete at BAS.
Fit another standard turbo. (Upgrade is a lot of cash) Upgrade your hoses and intercooler and go for a modest sympathetic tune that won't cause any irreparable damage. I know "some" of the tuners will just take your money and ramp the car up tas high as you are willing to pay. I know from experience Pete would fefuse. |
30th Jan 2021 4:22am |
After speaking with Pete at BAS, he suggested that I go for a stage 2 with upgraded turbo, intercooler, and hoses. So it looks like this is the route I will go down. Thanks for all your suggestions.
2nd Feb 2021 3:44pm |
bankz5152 Member Since: 02 Feb 2017 Location: South London/North Kent Posts: 2148 |
Contact Gareth at Empire Tuning. Based in Colchester but has agents around the country.
Also stocks intercoolers, hybrid turbos and VNTs. Website works, youll get a reply and youll get on going support after. I was so happy with the work he did on my 110 I started working for him Instagram @defender_ventures Empire Tuning - Agent |
3rd Feb 2021 5:48am |
Intercept Member Since: 27 Feb 2017 Location: Suffolk Posts: 587 |
+1 for Gareth at Empire who apparently has just been doing some remapping work for Aston Martin.
3rd Feb 2021 7:28pm |
Indeed!
Click image to enlarge Instagram @defender_ventures Empire Tuning - Agent |
3rd Feb 2021 8:11pm |
