Home > Tdi > 300Tdi - seems to be leaking from the distribution head |
Horneteer Member Since: 10 Feb 2015 Location: Cornwall Posts: 60 |
IIRC the oil pump is mounted on the crank at the front of the engine, so I see no reason why you couldn't take the oil filter housing off to change the gasket. Would be an idea to thoroughly degrease the area to check exactly where it's leaking first as there are quite a few oil connections in that area.
20th Jan 2021 12:04pm |
Oldowner Member Since: 26 Dec 2018 Location: South west Posts: 626 |
It is far easier to remove the injector pump to replace the distribution head o ring - only takes ten minutes if you have the pulley retaining tool in the timing kit.
There was a revised injector pump rear mounting bracket which is well worth fitting if you do remove the pump - it positions the pump correctly ans prevents the timing case flexing when the injector pump is reinstalled and bolts torqued up. What I would say is don’t fit the revised bracket without changing the oring as the bracket will hold the pump in the exact correct position it should be in, if it has been slightly out of position for the last twenty years then the slight change in position will then cause the old o ring to leak! In the uk the timing pulley kit is £20-£30 and the revised bracket is usually around £10. |
21st Jan 2021 4:32am |
Ah so we're taking fuel leak out of the injection pump rather than oil leak? My bad...oops.
21st Jan 2021 6:26pm |
Blackhat90 Member Since: 31 Dec 2016 Location: Forfar Posts: 86 |
Whats actually leaking ? oil /water or Diesel? the oil filter is no way near the front of the injection pump,,,
28th Jan 2021 12:17am |
Moneypit Member Since: 27 Feb 2018 Location: North Yorkshire Posts: 271 |
Anyone know the part number for the revised pump mounting bracket ? Rebuilding a 90 & 110 300tdi at moment and would like to reduce every future problem
28th Jan 2021 9:08pm |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6612 |
Insulting posts removed from the thread. 1988 90 Td5 NAS soft top
2015 D90 XS SW |
28th Jan 2021 9:13pm |
Will@LRW Member Since: 04 May 2019 Location: UK Posts: 185 |
Here you go: https://www.lrworkshop.com/parts/ERR6835 LR Workshop Find a Defender's history and spec: https://defender.lrworkshop.com |
28th Jan 2021 9:30pm |
Thanks for that, your a gent
28th Jan 2021 10:16pm |
