Home > Td5 > Charge light flicker at high revs. |
jeffersj Member Since: 23 Jan 2015 Location: Near Preston Posts: 431 |
I don't suppose that the drive belt is slipping at high revs without it squealing, how old is the belt or is it worn? Also try swapping warning light bulbs just in case it is on its way out. Jeff
Ex 1968 Series 2A Ex 90 TD5 Ex D3 Ex D4 |
26th Jan 2021 9:23am |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8099 |
if the battery is fully charged then maybe the alt is not charging it and hence the flickering?
whats the actual battery voltage? Cheers James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
26th Jan 2021 10:39am |
CRJ Member Since: 12 Mar 2011 Location: Sealand - Denmark Posts: 253 |
Thanks 👍 The belt is worn - but did not think of it as there was no squealing...but it needs to be changed anyway.
Voltage on batt is 12.8. when engine is at idle it is 14.7 Regards Christian 88 Ser. 3 1980 -sold Puma 130 - 08- sold 90 200tdi 1991 - sold 88 Ser. 3 1977 200 TDI 110 CC 2003 |
26th Jan 2021 12:13pm |
whats the voltage when the light if flickering?
When we built comp trucks with twin 100A plus alternators when the batts were fully charged the light would flickers or show very dimly, the latter being a more accurate description as the alts werent putting out much output as system didnt need it. 14.7 seems a little high. try measuring voltage at tickover across battery compared to back of alternator. then turn on lights and any other electrical loads what happens to the reading? turn them off what then happens? Try same at higher >1600rpm engine revs. let us know Cheers James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
26th Jan 2021 12:30pm |
Hey - really appreciate the help! Work just been draining me for a while😇...I will be around the car next week - and check as recommended.
4th Feb 2021 4:34pm |
6th Feb 2021 11:01pm |
