![]() | Home > Technical > 300Tdi flash/horn not working - interior light removal |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17600 ![]() ![]() ![]() |
If there was a spark, you've blown a fuse and it should be a simple fix.
donmacn Member Since: 06 Nov 2017 Location: Nth Scotland Posts: 1852 ![]() ![]() |
Yep - most likely a blown fuse. I had my son do this to me not so long ago. Because the interior lights are permanently live/earth switched it's easy to create a short. Donald
1994 Defender 300Tdi 110 SW - owned since 2002 - 230k miles and going strong (The 'rolling restoration' or tinkering thread: http://www.defender2.net/forum/topic58538.html ) 2000 Range Rover P38 4.0L V8 in the past.. RR classic - fitted with 200Tdi 1984 RR classic - V8 with ZF auto box 1993 Discovery 300Tdi not to mention the minis and the Type 2 VW camper... |
Rednaxela Member Since: 23 Sep 2019 Location: UK Posts: 41 ![]() ![]() |
Have just replaced the fuse and it's solved now. Thank you.
