Home > Wheels & Tyres (L663) > Anyone tried Bf Goodrich KM3
nikdim82
Greece
Hi,
Has anyone tried Bf Goodrich KM3 275/65 r18 for the new defender? Seems to have the same diameter with the proposed 255/70 r18 (eg Duratracs and KO2)
Post #876749 6th Jan 2021 8:29pm
camelman
They are only speed rated to 100mph. (Q)
Post #876751 6th Jan 2021 8:36pm
nikdim82
Greece
Correct. Intended to be used only off-road and have a second set of 20' wheels for everyday use.
Post #876755 6th Jan 2021 8:46pm
Retroanaconda
So are the Land Rover approved Duratracs, so I doubt that would be an issue.
Post #876759 6th Jan 2021 9:01pm
Why would a 100mph speed rating be of concern when our speed limit is 70mph?
I guess the exception may be if you go abroad I suppose, but generally speaking I don’t think many people would even contemplate over 80 in a Defender not to mention the legal ramifications that would entail too. TheThunder Rolls🇬🇧🇺🇸
Post #876785 6th Jan 2021 10:39pm
vogue se
Belgium 2011 Defender 90 Puma 2.4 Exclusive HT Nara Bronze
I live close to the German border and their Autobahns Very Happy . I'm going to try to do 119mph.
But not with offroad tyres.
Post #880690 24th Jan 2021 10:32pm
miker
You're in the new defender section Wink Significantly faster than our old tractors.
Post #880696 24th Jan 2021 11:53pm
AJC
i've seen 95 out of the td5 110 Embarassed
Post #880720 25th Jan 2021 8:20am
Digger2000
United Kingdom 2006 Defender 90 Other HT Tonga Green
I saw someone put Maxxis RAZR mud terrain 275/65/R18 on some TuffAnt 18” wheels without any lift or other modifications and they looked very good but not sure how they performed.
Post #880754 25th Jan 2021 11:18am
Tom_T
I’m planning on putting 275/65R18 Cooper Discoverer STT Pro mud terrains on my 90. I’ve run Maxxis mud terrains on my pick up and they are a good tyre but more aggressive then the Cooper. Noisy on road, but not unbearable and worth it when crossing muddy fields / forests and you don’t get stuck!!
Post #881486 28th Jan 2021 6:45am
camelman
Tom_T, its been mentioned before but the cooper STT PRO in that size, and many others, is only speed rated K (therefore legal) up to 68mph.
Post #881492 28th Jan 2021 7:33am
Digger2000
Will they fit on the LR steel wheels without rub or need of a lift rod kit?
Post #881521 28th Jan 2021 10:22am
Tom_T
Ahh I thought they did a Q rated tyre but that only seems to be the 275/65R20 which I don’t think will fit as it’s 45mm bigger diameter than the 18” version. Back to the Maxxis I go then as they are Q rated!!! I genuinely don’t go more than 70 in my truck I tend to just sit at 60/65 in the inside lane and I’d do the same in my defender but I’d like a bit more comfort on the speed rating. Thanks for the tip 👍
Post #881612 28th Jan 2021 6:55pm
