![]() | Home > Wheels & Tyres (L663) > Anyone tried Bf Goodrich KM3 |
camelman Member Since: 27 Feb 2013 Location: Peak District Posts: 3391 ![]() ![]() |
They are only speed rated to 100mph. (Q)
nikdim82 Member Since: 23 Nov 2020 Location: Athens Posts: 5 ![]() ![]() |
Correct. Intended to be used only off-road and have a second set of 20' wheels for everyday use.
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2713 ![]() ![]() |
So are the Land Rover approved Duratracs, so I doubt that would be an issue. |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20676 ![]() ![]() |
Why would a 100mph speed rating be of concern when our speed limit is 70mph?
I guess the exception may be if you go abroad I suppose, but generally speaking I don’t think many people would even contemplate over 80 in a Defender not to mention the legal ramifications that would entail too. TheThunder Rolls🇬🇧🇺🇸 ⛽️🛢️⚙️🧰💪 |
vogue se Member Since: 24 Jan 2008 Location: Bocholt Posts: 112 ![]() ![]() ![]() |
I live close to the German border and their Autobahns
![]() But not with offroad tyres. |
miker Member Since: 13 Sep 2015 Location: Surrey Posts: 1776 ![]() ![]() ![]() |
You're in the new defender section ![]() |
AJC Member Since: 30 Nov 2015 Location: Lancashire Posts: 1369 ![]() ![]() |
i've seen 95 out of the td5 110
Digger2000 Member Since: 19 Sep 2020 Location: Newcastle Posts: 590 ![]() ![]() ![]() |
I saw someone put Maxxis RAZR mud terrain 275/65/R18 on some TuffAnt 18” wheels without any lift or other modifications and they looked very good but not sure how they performed.
Tom_T Member Since: 08 Nov 2020 Location: Essex Posts: 87 ![]() ![]() |
I’m planning on putting 275/65R18 Cooper Discoverer STT Pro mud terrains on my 90. I’ve run Maxxis mud terrains on my pick up and they are a good tyre but more aggressive then the Cooper. Noisy on road, but not unbearable and worth it when crossing muddy fields / forests and you don’t get stuck!!
Tom_T, its been mentioned before but the cooper STT PRO in that size, and many others, is only speed rated K (therefore legal) up to 68mph.
Will they fit on the LR steel wheels without rub or need of a lift rod kit? |
Ahh I thought they did a Q rated tyre but that only seems to be the 275/65R20 which I don’t think will fit as it’s 45mm bigger diameter than the 18” version. Back to the Maxxis I go then as they are Q rated!!! I genuinely don’t go more than 70 in my truck I tend to just sit at 60/65 in the inside lane and I’d do the same in my defender but I’d like a bit more comfort on the speed rating. Thanks for the tip 👍
