![]() | Home > In Car Electronics > dcpu rear speakers |
Matt110 Member Since: 29 Jun 2014 Location: UK Posts: 685 ![]() ![]() |
JOE_130 and I made up some speaker boxes for the rear of his DC. Couldn't find anything to buy. We just cut out marine ply in the right shape such that the speakers would fit behind the seats (which aren't fitted at the moment).
Think it depends what speakers you want to fit. We fitted 6.5" components. They sound good without a sub although he also has a 12" sub box we made to fit in the middle, all along the back above the rear "shelf" that's created when you take the seats out behind the seat box. Photos would be good but haven't got any at the minute. Are you trying to fit them up high or down low? |
Christophe Member Since: 18 Aug 2020 Location: Sint-Truiden Posts: 12 ![]() ![]() ![]() |
Considering the focal pc165's and a woofer to mount behind the seats. 04' 110 TD5 Double Cab
10' 90 2.4tdci Station Wagon |
Should work OK as they're the same size as ours.
Make up a triangular flat faced box to sit behind the seat pushed into each corner on the ledge behind the seats. Doubt a sub would fit behind there with seats still fitted, but we were considering making a second iteration that used the seat box as the sub volume so that might be an idea. No wasted space then. |
hank Member Since: 12 Sep 2016 Location: South Wales Posts: 2316 ![]() ![]() ![]() |
Just a suggestion, fit the focal's in the front with a woofer under the rear seats and you may well find you don't need rear speakers too
![]() ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge > 110 XS Double Cab |
ay4alex Member Since: 18 Feb 2009 Location: Midlands Posts: 328 ![]() ![]() ![]() |
Yep, done that - 6.5" Hertz speakers under the rear seats in custom boxes, and a 10" sub in custom enclosure - running of a 6ch amp under the drivers seat.
![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge 110 Tdci Double Cab |
BenB8man Member Since: 22 Mar 2017 Location: Norfolk Posts: 431 ![]() ![]() ![]() |
Those speaker boxes look great! Do you happen to have plans or measurements for them?
Grenadier Member Since: 23 Jul 2014 Location: The foot of Mont Blanc... Posts: 5878 ![]() ![]() ![]() |
Like Hank, I’ve swapped the standard DC speakers with Focals and added the Focal ibus amp/sub under the rear seats. I’ve bought two more pairs of focal speakers and will (when I get my arrrrse into gear) fit the 10cm in the headlining above the b-pillar and the 13cm pair in the headlining in the rear corner about the corner windows, using spacers to add depth. They will then be wired into the head unit using the Focal 4.320 mini amp, which I shall fix under the dashboard cover over the passenger side handle. That provides a six-speaker, two-tweeter, one-sub (9-speaker), two amp set up, with 50% above head height, 50% at head height. I have soundproofed the whole cabin, including adding high density egg-box sheet behind the rear seats and a super thick sound blanket between the headlining and the roof.
![]() https://www.focal.com/en/car-audio/car-aud...pulse-4320 Monsieur Le Grenadier I've not been everywhere, but it's on my list..... 2011 Puma 110DC - Corris Grey |
