![]() | Home > General & Technical (L663) > 2020 Defender + Tow Bar + Bike Rack |
orled Member Since: 02 May 2013 Location: NWest Posts: 18 ![]() |
Just measured, approx 55-60cms with spare wheel cover on, door angle open approx 35-40 degrees Certainly possible to take items in and out of boot easily ![]() Click image to enlarge |
Dharbison Member Since: 18 Jul 2020 Location: Bendigo Posts: 2 ![]() ![]() ![]() |
Of interest I’ve received a Yakima backswing and holdup which I’m hoping should fit.
I thought I’d be a great way of getting around the spare wheel and being able to open the door at the same time. I’ll post some photos in Sep when I receive our defender. |
Chioti Member Since: 03 Jan 2021 Location: NJ Posts: 25 ![]() ![]() |
Did you get a chance to install and take a couple of pictures?
Og250 Member Since: 18 Feb 2021 Location: Sussex Posts: 45 ![]() |
I was wondering please:
a) Is the Thule a better option to the LR accessory bike carrier (which is probably made by Thule)? Looks a similar price and the Thule appears to be a higher grade than the LR. b) Can you get the Thule into the boot (I think the LR accessory claims it fits in the boot), and if not, how theft proof is it left on the back of the car? c) Have you tried removing the spare wheel and using the inner most bike carrier? i.e. opening up the possibility of carrying up to 4 bike with the additional add-on. I wondered if this was a viable option with carrying a compressed air/foam repair kit instead of the 5 wheels on the odd occasion? Car on order so looking for the best 4 bike option for the tow bar. For short day trips I will put one of the kids bikes (8 year old sized) in the boot and use the Thule plus the add-on as a 3 bike carrier. |
Ipe Member Since: 29 Nov 2020 Location: MA Posts: 21 ![]() ![]() |
The Defender is offered worldwide and the options for rack attachments seem to differ greatly depending upon your geographic region. The tow hitch attachment seems to be much more simple in North America so the solutions we have may be radically different from what can be employed elsewhere. I hope this helps.
I've been mountain biking since the dawn of the sport in the 1980's. Since then I've owned racks from all the major manufacturers. After having owned so many and finding them all lacking I've come to what I consider the best of them all: 1Up-USA.com. Without question they work the best of all I've ever owned. So much so, that I own two of them, a single and a double (which I'm giving to my son). To make them work well with the Defender I've coupled them with a Kuat Pivot v2. The Pivot swings the rack away from the door and out of the way. It's stable on the roughest of roads and appears to be very stout. Pity its not made from aluminum as eventually it'll rust. Despite the future rust I wholeheartedly recommend this setup. It's simply excellent ![]() ![]() Click image to enlarge This picture shows the pivot open to 120 degrees. There is a positive stop at 90 but not at 120. ![]() Click image to enlarge This picture shows the door open and the rack locked at 90 degrees. There is clearance for the wheel and a pedal here. If I flipped the bike around there would have been ever more room. ![]() Click image to enlarge The single place rack folded up for storage and the Pivot locked in place. If the rack were folded down like in the picture above the door will open over it ![]() Click image to enlarge Double rack folded down. The door will NOT clear this rack in this position. You can fold it down even more but at that point its easier to open the Pivot ![]() Click image to enlarge Double rack folded up. For what its worth 1Up makes solutions for up to four bikes and the Kuat Pivot v2 is strong enough to handle all four provided they're typical road/xc/trail/enduro/downhill bikes vs e-bikes |
This looks great - a swing out rack would be ideal. Unfortunately in the UK we have tow balls only (electronically deployable tow ball only on the XS), so I think this limits a lot of the good options out there.
I think it’ll have to be the Thule Velospace XT3 (as in post further up). Will only fit 2 bikes normally, but with the additional bike fixture plus removing the spare wheel it may do the full 4 it’s designed for |
Nitroneil Member Since: 05 Mar 2019 Location: Stirling Posts: 132 ![]() ![]() |
I wonder if getting a plug in towbar chopped and welded with alternative mounting bracket would be an option to allow the swing away one to be fitted. The pivot one does look to be the best solution. UK
Edit. Have just spotted this, wonder if it works OK. Would give a decent mounting point to bolt to. As opposed to modifying bar. https://www.wilmond.co.uk/clam-shell-swan-...aptor.html 90S D250 fuji and loving it. |
zabelvelo Member Since: 17 Jan 2022 Location: Lancs Posts: 1 ![]() ![]() |
I'm looking to use an XT3 on my 110 but as of yet no tow bar - would you mind measuring from bumper to centre of extended tow ball so I can ensure that my aftermarket tow bar is at least as long as your factory fitted one so I can be sure I will have sufficient clearance?? thanks |
Orchard Member Since: 07 May 2015 Location: Usually walking the dog Posts: 258 ![]() |
Here’s my solution, can get my 3/4 bike rack on. It looks a bit precarious but is solid enough!
![]() Click image to enlarge 2015 90 XS SW Bowler 1998 TD5 CSW |
Bumpy Member Since: 07 Sep 2016 Location: Hampshire Posts: 17 ![]() ![]() ![]() |
This is my setup. Watling Engineering tow ball conversion kit - officially rated at 150kgs but I gather has been tested a lot higher.
I’ve yet to venture out with 4 bikes but it will only need it to take the weight of two adult bikes and two kids bikes at the moment. 4 ebikes would be a definite no. The 1 up rack is amazing. Doesn’t touch the frames, only the tyres and is super easy to attach and detach. ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge |
1986RRC Member Since: 11 Mar 2022 Location: Nicosia Posts: 4 ![]() ![]() |
Hi,
Do you mind posting a couple of close up photos from different sides of the Watling Engineering tow ball conversion kit/adaptor? I contacted them because I need one myself but they do not manufacture them anymore due to lack of specific materials. I maybe able to ask a friend to manufacture one for me. Thank you By the way, your set-up is excellent. I am buying the 1-Up bike rack as well. |
![]() Click image to enlarge ![]() Click image to enlarge here you go ![]() |
Thank you very much for the photos!
Now I have a clear idea how it's made. cheers |
LR Nuts Member Since: 10 Aug 2022 Location: UK Posts: 1261 ![]() ![]() |
google Bak-Rak, they have a patent 'ball coupler', with many options.
