![]() | Home > Td5 > Talk to me about sound-deadening |
I bought a lot of Silent Coat for my 110 DC. However I've decided against it on further research I'm going to coat the panels (bulk head, roof, rear of cab, floor panels, doors etc) with Lizard Skin. I think I will use the Silent Coat on my Cooper S instead which doesn't suffer from the condensation issues the Defender has.
bluebottle Member Since: 08 May 2015 Location: Not in my Landy enough! Posts: 705 ![]() ![]() |
Ah... that's worrying. Can you share a link or anything to the issue please?
I had read that Silent Coat uses mastic as adhesive, isn't that what seals shower trays etc? I wouldn't have thought a bit of condensation would be a problem? |
I don't think theres any great risk with Silent Coat providing you don't cover the seams etc. I wasn't won over with the idea of just sticking things on the panels.
Since Silent coat is an anti vibration and I didn't like the bitumen coating / the need for a total vapour barrier with the tape etc. I also didn't like the idea of it being 'stuck on'. Probably being more pendantic than I need to be with a farm truck, however I liked the idea of the Lizard Skin a lot more, it seemed to cover more bases (durable, paintable, longer term, ceramic insulation etc). I was always put off seeing all these refurbished cars covered head to toe with dynamtt type stuff, I always thought there would be a better option so thats why I'm going with Lizard Skin. |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8172 ![]() ![]() ![]() |
Sorry for ot talent, how does lizard skin attach? Cheers
It’s spayed on like raptor, but rescues its own gun which comes in the kit, needs air though.
Don't be put off by lord-haggis - plenty of us have used Silent Coat to great effect and without issue. To get the best out of it, you need to combine it with some closed cell foam though, typically 6mm thick. The Silent Coat stops the panels reverberating whilst the foam absorbs airborne sound.
I started at the other end in my USW, including removing the head lining. So far, I've only done the roof, rear sides and tub plus the inside of a couple of doors and the difference is remarkable. This was it part way through the process: ![]() Click image to enlarge There's more details of what I've done on my build thread here: https://www.defender2.net/forum/post711655.html#711655 Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
Co1 Member Since: 19 Aug 2018 Location: North Yorkshire Posts: 3700 ![]() ![]() ![]() |
What LRA said. I did my 90 in the same fashion and went from listening to the radio on volume 15, to being able to comfortably listen to it at 10.
Fabio Member Since: 05 Aug 2011 Location: Somerset Posts: 589 ![]() ![]() ![]() |
I did mine during the last lockdown and although I didn't use silent coat, I think it is one of the best upgrades you can do to the defender.
Fabio |
