![]() | Home > Puma (Tdci) > Another rattly Puma post |
kingofthesparks Member Since: 06 Jan 2011 Location: Very close to Watford gap services , northants Posts: 987 ![]() ![]() ![]() |
My 60 plate 110 utility done this but it seemed intermittent usually worse on cold mornings, sound is very disturbing for a new motor, never found cause as i sold it to buy a 110 dc tomb raider and a d3 as well.
Get the same from mine when I have been offroad and using low ratio a lot.
Back on tarmac and high range I get a similar tappet type noise. After 40/50 miles it seems to sort itself out. I use decent (Esso ?) fuel and 2 stroke as well. Dealer looked at it earlier this year and could not find anything amiss. It used to be a lot worse when I used Shell Fuel Save so my best guess is that it may be fuel related. I just live with it now ![]() Bob |
Fun enough i was using shell, may have had something to do with it as it was intermittent and now and again i used bp
Denis Member Since: 28 Dec 2010 Location: prairie Posts: 58 ![]() ![]() ![]() |
Also have such sound on several Pumas (of my friends) - thats not a problem at all. All on new (low mileage) engines.
Cheers ![]() |
rossy Member Since: 29 Nov 2010 Location: Co. Roscommon Posts: 1296 ![]() ![]() ![]() |
thanks for the replies everyone. I too have no problem living with it either as long as there's nothing wrong
Forest of Dean 90 Member Since: 29 Apr 2009 Location: Forest of Dean Posts: 68 ![]() ![]() ![]() |
Mines the same 07 plate 45,000 miles
sounds awful, is it clutch, gearbox, transfer box or engine ? |
spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4742 ![]() ![]() |
I suppose you have checked the obvious and checked the bolts on the heatshield on the turbo.Sometimes they need to be tightened,especially the one nearest the front of the engine. Mine needed tightening and was causing a bit of a racket but maybe that is different. 1982 88" 2.25 diesel
RED-DOT Member Since: 29 Jun 2009 Location: stirling Posts: 2363 ![]() ![]() |
Check the red engine lifting eye, they all come loose then fall onto engine. 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
thanks chaps yes I checked those they seem to be a common problem
nicknick Member Since: 28 Feb 2011 Location: halifax Posts: 30 ![]() ![]() ![]() |
Hi guys,
my puma with 3000mls on did exactly the rattle your all talking about, its definetley a combustion noise. Mine runs fine apart from the noise, when i had my remap done the noise could be made worse or totally gone by adjusting the injection timing using a laptop, im talking about tiny amounts 0.25 of a degree or so. Now its totally gone and far more pleasant to drive. One of our transits did the same noise and we had the timing adjusted (no remap) and thats 100% better too. You see all modern engines are mass produced and all the same......, only there not ! this is proven because all engines have a variety of diffrent thickness head gaskets available (2 or 3). This is because of manufacturing tolerances so it stands to reason that one injection timing setting isnt going to suit every engine ![]() bloody hell im boring sometimes , sorry ![]() |
wslr Member Since: 18 Jul 2010 Location: Wellington, Somerset Posts: 581 ![]() ![]() |
Taken from the User Manual:
There is no obvious TSB linked to this unfortunately, but does this mean that we should be using premium diesel like BP Ultimate. |
And this may possibly help someone, but only relevant on early MY's:
Nick you are not boring ! That sounds like a plan for next time I'm at the dealers. Many thanks |
shrekman Member Since: 11 Aug 2011 Location: worcestershire Posts: 20 ![]() ![]() ![]() |
Hi. Now that interesting I thought I was alone with this issue And finally got the steelers to fit 4 new injectors to cure my rattle. It didn't cure it. Thank god I'm not alone. Any other info on the injector timing ????? spent 20 years fixing them ... the dealers just wont listen !!!! |
